Question about Health & Beauty
Rechardable battery . can you tell me how to take apart a remington shaver. to change the batterys. i have MODEL NO, MS2-300 RS4843. YOURS D.Sweeney.
  • Health & Beauty Master
  • 1,623 Answers
First, remove the foil and cutters. You will then need to gently pry off the rubberized front cover with a small flat screwdriver or similar object. You will then be able to access and remove the two screws at the bottom. You will then need to pop the case apart by carefully inserting a flat screwdriver at the bottom between the AC port and the case. Once you pop it apart you will need to remove the metal clip at the top that so that the case can be fully seperated.
You will then be able to see the batteries.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If this is not something you can do yourself, you might want to consider one of the items below which will give you and easier fix
http://shaveroutlet.com/remington-ms2370-lower-unit-p-208.html
http://shaveroutlet.com/remington-ms2100-lower-unit-p-209.html
Posted on Apr 24, 2010
Testimonial: "thank you this was veryhelpfull great many thanks"
How do you remove the battery from a Remington Dual Foil 30 Shaver?
There are two screws on the back just under where the cutter fits on. Remve shaver head then remove screws and you can then gently pry the front and back apart from the top.
If you need replacement batteries, you will find them at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
Dec 20, 2010 | Remington Health & Beauty
Hello, I have had a Braun 5564U model shaver for years. I used in up till last week when it quit running altogether. At that point, the led light will also not illuminate and the unit does nothing. I...
Most likely, you have damaged the circuit board from using it directly from the cord for so long and not changing the batteries when they were needed. The fact that the chatging light no longer illuminates tells me that this is probably the case. However, it is possible that only the batteries are bad. It is pretty hard to tell which it is without installing new batteries though. If you want to try new batteries, you will find the correct type at shaveroutlet.com.
If your unit has two batteries, order two of the type linked below
http://shaveroutlet.com/shaver-replacement-parts/batteries/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If yours has only one battery, you need this type:
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-replacement-battery-aa-nimh-p-108.html
Nov 16, 2010 | Braun Flex XP 5614 Electric Shaver
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
Change battery
Most MS3 series models were not designed for battery change. The shaver body is glued together and it is extremely difficult to take apart without marring it all up.
shaveroutlet.com sells the shaver body for a very reasonable price. I suggest you consider this item instead. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 02, 2010 | Remington Titanium MicroScreen MS3-2700...
Battery changing
I have a Reminigton (PG-250) beard trimmer that is very similar in appearance. I was able to get to the battery by inserting a small screwdriver into the botton (where it plugs in) and twisting the bottom and top halves apart. There are no screws. Once you get it started, just go around the groove and pry it apart.
Nov 08, 2008 | Remington Smooth and Silky WDF-3000...
Remington shaver RS4843 Microscreen 2
Bypassed batteries. still no good. bought new shaver
May 14, 2008 | Health & Beauty
Health & Beauty Logo
278 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
