Some software or hardware problem is there.due to which the system is not starting,the booting does not completes and again it repeats the same process.
  • 109 Answers
You have not mentioned like where exactly the boot process stops.. But still Try booting up the pc in safe mode tapping f8 during startup. If it does'nt work then go to the bios screen by tapping f10 during start up and do a hard drive self test .. if the test fails you have to replace the hard drive.. But if the nb does'nt go to the bios screen then you have to take the nb in for repair its a hardware issue..
Posted on Apr 30, 2010
Launch startup repair
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Boot in safe mode or the operating system equivalent.
Windows, Unix/Linux and Mac operating system have a mode that will load the minimum software needed to boot.
This is a standard approach in troubleshooting, as it only supports the minimum hardware needed to complete the boot into the operating system.
Once you are logged into the computer, device drivers can be updated, software removed and so forth.
To boot into safe mode in Windows, hit the "F8" key when the computer first starts up to get a submenu.
From there select a boot option. Many choose "Safe mode with command prompt" as this will go line by line through the boot process, allowing you to isolate where the problem might be.
To boot into a different run level in Unix/Linux, it depends on the version of Unix/Linux, but most have the option of a "recovery mode."
During boot hit the "Esc" or "E" key and select the mode appropriate such as "drop to root shell," etc.
If you have the ability to get into command shell, enter into run level 1 (single user mode) by typing in "init 1."
To start in safe boot on a Macintosh laptop, hold the "Shift" key as it boots up.
This forces a disk check and loads minimal software in efforts to complete the boot process, much like the other operating system's "safe modes."
Check to see if your laptop is overheating.
Laptops have a greater likelihood of overheating than desktops.
Either touch the laptop or download an application such as Mobile Meter to check laptop temperature.
If it is running hot, try using canned air to clear out of vents, etc.
Also, elevating the laptop off of its resting surface allows greater airflow in and out of the laptop
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Nov 27, 2012 | Toshiba Satellite C655-S5049 Notebook
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Hi, I am suneel here.I am having Dell vostro 1500 laptop with windows Xp.i was trying to format my system.but i was not able to format the system.so i removed the CD and restart the system But its...
Insert your windows disc. Make sure its booting from the disc drive. Let it load. Select REPAIR COMPUTER. Recovery console comes up. Choose your windows intallation (C:). Type your password (if there isnt one leave it blank), press enter. Type in CHKDSK /R. Let it complete the scan. This should fix your problem.
Mar 14, 2011 | Dell Vostro 1500 Notebook
Windows failed to start. A recent hardware or software change might be the cause. file\boot\bcd status 0xc000014c info an error occurred while reading the boot configuration data.
Check the hardware connectivity of your Hard drive and Cd rom drive. Check if the wires are plugged properlyand are not loose. This error is generally thrown when your system is not able to find the boot sector in other words it is not able to find all he information (all necessary file pointers, kernel info And Master Boot Record etc) which it needs to start the system.
In most cases this is a temporary issue and occurs due to loose connections of the cables from Hard drive or CD Rom ( if the system is being booted up from CD).
Nov 18, 2010 | Computers & Internet
Starts up till time to put in users name blacks out tryes to restart then repeats same thing
installed anything new? hardware? software?
sounds like a conflict problem, if new hardware installed, try removing it.
if new software installed, boot in safe mode (press F8 while booting, and choose safe mode). or maybe a corrupted registry file, you will need to repair it or reinstall system.
Aug 14, 2009 | Dell Inspiron 1525 Notebook
XP Doesnt get to log in screen
Try to repair the OS, if you have the installation cd.. or format it then install new OS...
Jun 24, 2009 | Computers & Internet
I have a blue screen.. How can I get that off?..
Reboot into Safe Mode. While rebooting keep tapping on F8 to go to Safe Mode. Once there select "Last known good configuration" and press Enter.
Jan 31, 2009 | Computers & Internet
I have a GT5064 computer. now the computer be booted reaptly and never go into Window system
Can you boot into safe mode?
To do this press F8 (repeatedly) straight after the bios screens during the first part of the boot process. If you see the windows logo you have missed it and you will need to start again.
Depending on your opperating system you will get different options.
Did you recently install new software or drivers or hardware that may have caused this problem?
If so try the option "Last Known Good Configuration"
If that doesn't work reboot again and choose "safe mode"
Let us know if safe mode works and normal mode does not.
Let us know what happens and how far it gets through the boot process.
The more information the better.
Oct 21, 2008 | Gateway Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
