Hello Wardens wife
There is no filter time menu in Hitachi CP-X385
so how u say reset filter time.
There is only Lamp Hours Time Reset menu.
I am usinng this Projector Hitachi CP-X385
Can u tell me where is filter located in Projector Hitachi CP-X385
  • mahan333 Apr 15, 2009
    None of our Hitachi cp-x880 projectors HAVE a filter entry in the options menu.. just a lamp hour entry.
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Posted on Apr 21, 2009
  • 563 Answers
Hi Airbala
This Projector does have a filter timer.
Go to the Options Menu and select Filter Time - then reset it.
Posted on Mar 26, 2008
SOURCE:
Re set timer?
hi,
To reset the lamp hour timer do the following,
1. Power on the projector
2. press the menu button
3. Select option
4. in the option menu select Lamp time
5 press and hold the reset button on the remote or Right arrow button on the projector for 3 seconds
the lamp reset diagonal box will appear
6 using the up arrow button select reset.
Also try to reset the filter time using the same procedure
lamp reset is recommended only after the lamp replacement.
ok
Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
Lamp and filter lights flashing and we have just changed a lamp.
Reset the filter timer
The filter time is the time counted after the last resetting.
It is shown in the OPTION menu as the use time of the air filter.
Pressing the RESET button on the remote control for about 3 seconds displays a dialog.
To reset the filter time, select the RESET using the UP arrow button RESET and CANCEL
Mar 25, 2011 | Hitachi CP-X345 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
How to clean air filter in HITACHI CP-X385
On the right side of the projector there are vents, put a vacume cleaner up to the vents, and the filter will be cleaned.
then on the top of the projector click the down arrow, then go down to option, use the down arrow to highlight the filter time, then hold the reset button on top of the projector for about three seconds. Clean the air filter every 100 hours.
Mar 17, 2008 | Hitachi CP-X385 Multimedia Projector
Hi there
Look at the bottom of the Projector , you'll see a thin grey line with two edges on it. That is the filter. Grip on the sides and gently pull it out.
Mar 17, 2008 | Hitachi CP-X385W Multimedia Projector
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Dec 12, 2007 | Hitachi Office Equipment & Supplies
Open Questions:
1,970 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
