Question about Sharp AR-5320 Black and White Copier
F BLINKING THE MACHINE CUOULD NOT OPERATION, F BLINKING
  • 328 Answers
Change toner cartridge,
Posted on May 30, 2010
Qinghaihu m2vhrh audio driver
can u plz name the model of your pc ?
Sep 23, 2013 | HP Computers & Internet
Error sc 870
One possibility:
Address book data stored on the hard
disk was detected as abnormal when it
was accessed from either the
operation panel or the network.
?? Initialize the address book
data (SP5-846-050).
?? Initialize the user information
(SP5-832-006).
?? Replace the HDD.HDD defective
Secondly:
When the machine reaches the Ready condition after boot-up, the operator turns OFF the Main Power
Switch without first pressing the Operation Switch. As a result, the flash memory on the controller board is
damaged, triggering the SC.
SOLUTION:
1. Please be aware of the following:
Before turning off the machine's main power, always make sure that the Operation Switch LED is not
lit or blinking. By turning the Main Power OFF while the LED is still lit or blinking, may cause damage to
the machine's hard disk or memory.
Feb 22, 2013 | Ricoh Aficio Mp3350b Digital Copier...
Samsung star II duos GT-C6712 -
for step by step procedure,on how to connect.Click the link below:---
http://answerguide.blogspot.com/2012/01/how-to-connect-internet-through-airtel.html
-----------Thanks.
Jan 20, 2012 | Samsung star II duos GT-C6712
It beeps and rotates a blinking "H" and an "F" in
No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps blinking FH and stopping
Or
Potential Causes
Nov 29, 2010 | Washing Machines
Panafax UF885 unresponsive. Display is flashing UF-855 (AU). I replaced the battery and even went back to Radio Shack to make sure it was a good battery. I also tried: Remove the toner cart Pull up on the...
Hi, you have done all you can do. Your fax machine has a bad main board. At LEAST $600.00 to repair.
Sorry.
Just thought of something..... Lift the operation panel....There is a 5 inch log cover on the rear top of the machine held down with 1 screw. Remove the cover. if there is a memory card sticking up, remove it and try the shipment set again.
Nov 30, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
When machine is put on, it keeps blinking with UL.The machine is new and we do not know the codes for errors and operation.
Hello sir; If your machine is new, then you got to have user manual. check inside see what 's meaning, if still can't find then go to simulation 14, the procedure as follow; press "#", "interupt", "o", "interupt', then enter 14 press start.
Jun 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
