Question about Plumbing
My WD1001 waste disposer has stoped working - Plumbing
  • 43,501 Answers
Some disposers come with a hex wrench that you can put into the bottom and spin them. If you don't have that a piece of wood like a broken broom handle can be used to spin the disposer from the top...
If it spins freely tehn look for the reset button 2/3 of the way down the side of the motor. push it in hard till it clicks...
If all this fails you will have to replace the unit...
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
heatman101
Posted on Apr 25, 2010
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 | Plumbing
My kenmore disposal doesnt work it only hums
It is jammed the way to fix it is to use wooden broom stick and place the handle side in disposal and let it engage on the side pull stick back and forth till you free up the cutting blades. Then test it to see if it works. This happens a lot with disposals.
Mar 25, 2014 | Kenmore 1 hp Food Waste Disposer
Blocked waste master wd1001
need a bit more info here...what is this a washing machine? A garbage disposal?
Jun 10, 2012 | Washing Machines
Stoped running. Is there a re-set button
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Dec 14, 2010 | GE Continuous Feed Garbage Disposal...
The badger 5 has just stoped working
There are three possible things.
1) Circuit breaker tripped
2) Wall switch gone bad
3) Reset button tripped on disposal
Reset is located near where wire connects to disposal
Nov 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I never put potato peels in but in the 3 months I have owned this house it has stopped up twice. Why?
The problem should really have nothing to do with potato peels. Even a cheap disposer should have no problem chewing up things much worse than that.
There are two main things that could be causing your problem: 1. Defective disposer or improper installation 2. Improper usage of disposer (more likely)
I've been known to put entire sinkfulls of waste down the diposer (mine is an ancient thing from the 70s), and I've had a clog maybe once. You have to be conscious of the amount of water that's going down with the waste. Ideally, before anything solid at all goes down the drain you should turn the faucet on COLD full blast and then turn on the disposer. The grinding mechanism is so fast that the disposer shreds the solids and blows them into the drain pipe at a very high rate. If there's not enough water down there to get thrown down the drain pipe with the waste that's when a clog happens. So don't turn the disposer on AFTER putting a lot of waste down there and always do it with a full flow of cold water. Feed the disposer gradually with the waste and let it run until it sounds empty.
When done right, the worst clogs can easily be dispatched with a plunger in three or four strokes. With a toilet the best way to it make sure the plunger is sealed good and plunger with short, fast, powerful strokes. When you unclog a disposer, the clog is almost always in the connection where the disposer discharges into the drain pipe because of the funnel effect. When you push the plunger down the water pressure will go up but the waste will compact tighter and resist flow even more. You want to push the plunger down and let it leak until you get it as far down as possible, then let it form a good seal and give a powerful upward stroke. That'll create strong suction and pull the clump of waste particles back, where they'll mix with the excess water and go right down the drain. If you don't have a plunger, you'll find that for some reason a soda can will work in a pinch.
Oct 30, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger 5 Not grinding waste
Hi, No, but the blades wear out after a while...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Mar 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Plumbing Logo
59 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
