Question about Hobart AM15-5 Dishwasher
Water pressure low during the wash cycle
During the restaurant working hours the machine took 15 mind to drain and after that, when it would wash a load the water pressure was almost half the regular pressure. I dont know what to do pls help!!!
  • 12,061 Answers
    Scholar:
  • 122 Answers
It sounds like there may be an obstruction in the drain. once the washer is drained, in the bottom right corner there is a basket that you can pull up and clean out. As for the water pressure being low...The machine uses a pump that supplies the wash cycle, but on rinse it uses fresh water.You may have a pump that is clogged or losing pressure good luck hope this helps
Posted on Apr 24, 2010
  • h8bnpo Apr 22, 2011
    The pressure can be adjusted at the regulator clockwise turns up the pressure.the line strainer could be plugged.
GE Dishwasher Model GSD900X-02 drain pressure problem
Wow, good job looking at all the possibilities. I have to ask, since you already bought the pump did you try it? Put the new pump in? Some machines like washing machines use a transmission, it is possible that the pump is sufficient for one function and not another. For what it is worth the first thing I would do is try the new pump. I know it was probably expensive and if it is not the problem you might want to return it but as you have discovered there are not many parts on the machine to fail. Most likely it is the pump or the valves and cillinoyds the pump moves water through like you have already surmised. If you do not wish to install the new on you might be able to uninstall the old one and see what it looks like running dry for just one second. my guess if it is not strong enough to pump the water 12" and a 12" water coulomb is only .5 Lbs (1/2 of a lb.) then there definitely is not enough head pressure on the pump and like you said it would have to be a leak or an open valve (the pump should produce at least 15 to 30 psi, city water pressure in many cites is 35 to 80 psig) so I would go for it, replace the pump. Good Luck.
Sep 14, 2014 | Dishwashers
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
My washing machine will not hold water during filling at the beginning of the cycle. It will constantly run for about 30 min to an hour. Then it will not switch to the rinse cycle. Please help???
The water is siphoning out the drain line because it is too low or is closed off at the top causing no air to enter the drain.
The drain line should be a minimum of 36 inches from the floor.
Jan 06, 2011 | Admiral AW22 Top Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The fabric softner isn't draining during cycle but the bleach and detergent do just fine. I took out drawer and cleaned the dispenser but still won't empty. Help!
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Dec 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Hobart AM15-5 Dishwasher Logo
227 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
