Question about Dell Computers & Internet
Screen reads windows error recovery - Dell Computers & Internet
  • Dell Master
  • 6,993 Answers
this means you windows operating system files has bee corrupt for one reason or the other.
Restart your computer, press f8 immediately, then a windows option will come up, select "Safe mode and press enter", you system should boot from there, then you can repair the corrupt windows from there.
You will bee needing your windows operating system Cd (Win Xp or Vista, depending on the windows you are running)
Good luck.
Posted on May 02, 2010
How can I recover my cr700 when after going into recovery mode I have nothing on screen.the mouse works but blank screen.i get the win logo and loading windows files but nothing after that. I have tried...
If you have backed up your data (photos, documents, etc.) on an external hard drive, USB disk, DVD's.
If there is company data, or otherwise valuable data, this is better left to a professional! If you are able to cope with the possible loss of all your data, feel free to continue reading.
If you're unable to backup your data, you might try to do so with:
Easeus Data recovery Wizard
Data Recovery Wizard Free 8 6
After you have baked up your data. You could try to recover windows from the error by:
-Pressing F3 repeatedly when the unit is powered on.
-This will get you a menu to load Windows, or Windows recovery
-After this, select "Windows Sytem Recovery Options"
-Follow the on-screen options to try and fix the issue
-If this doesn't work, power on the laptop again and press F3
-load up the Windows option that you are given
!THIS WILL DELETE ALL YOUR PERSONAL DATA AND RESTORE THE COMPUTER TO FACTORY DEFAULTS!
-Select "MSI Recovery Manager"
-IF YOU ARE SURE IT'S OKAY TO LOSE ALL DATA: "OK" > "OK"
-IF F3 Doesn't work, either your recovery files are missing, or your hard disk is failing. If this is the case, you can read on at:
Reinstalling Windows when recovery fails MSI HQ User to User FAQ
Hope this helps!
Feb 28, 2015 | MSI Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
My Studio 1535 has crashed. It will not reboot Vista. When I turn it on it will show the Dell Splash Screen and then go to the "Windows Error Recovery" screen which shows these options:...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 23, 2011 | Dell Studio 1535 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
Help! My Dell latitude d800 beeped than the screen went white. Than turned aqua so I turned it off for a half hour. When I turned it back on the windows screen pop up. Then it went blue and started...
i think there is problem with your video driver or lcd
you should hook your dell with external monitor and look out for error and then download a recovery cd from following link
Windows Vista Recovery Disc Download — The NeoSmart Files
Burn it to cd and boot your laptop with this cd and it will repair your windows
Jul 21, 2010 | Dell Latitude D800 Notebook
Error Code: Oxdooooo1e
this is a memory fail...and it is usually caused by errors on the disk or ram memory ...try to not use the recovery disk .and instead use a clean windows and boot until you have the choice to delete the partitions and format again from scratch..
after that install to the end and use the recovery cd just for the drivers ...
Jan 28, 2010 | Acer Aspire 3680 Laptop
Laptop starts and after a while of using a blue error box falshes on the screen and turns off comp I can't even read the blue box its sooo quick!
That is called the BSOD (Blue Screen of Death).
try a chkdsk:
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type Chkdsk C: /R at the prompt.
Or try a XP repair:
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | Sony VAIO VGN-T1XP/L Notebook
Shut down of laptop after blue screen appears
When you hit F12 or whatever F key to go to the boot drive menu, make sure the cd is in and that you select CD/DVD Drive and the dvd should prompt you to hit any key or will automatically start loading for the recovery. Just tell me if you need further assistance.
Feb 01, 2009 | Toshiba Satellite A135-S2386 Notebook
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Computers & Internet Logo
41 people viewed this question
Alun Cox
