Question about Maxent MX5020 50 in. Plasma Television
We threw away the TV pedestal and used the wall mount, now we want to purchase another pedestal so we can use it for stand alone. Where can we find it? How much is it?
  • 2,318 Answers
I might have one from a 42" maxent plasma that could fit on your plasma.
I will measure it and post the the dimentions if you're interested.
Posted on Apr 24, 2010
I can't find a pedestal for my Toshiba 37hl67 tv. I previously had this mounted to the wall and through the pedestal out
Check out TVPartsGuy.com i know they have a large inventory on TV Stands. Use promo code JVC10 to get 10% off of all your TV Stand purchases.
Apr 15, 2012 | Toshiba 32HL67 32 in. LCD Television
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Where can i buy a plastic tv stand for my sylvania LD299SL8. It got thrown away when we wall mounted it. now i want it to sit on a stand
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Dec 14, 2010 | Sylvania 6427FB 27" TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
Jul 14, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Maxent MX5020 50 in. Plasma Television Logo
226 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
