Question about Logitech Harmony 670 LCD Remote Control
Display on remote is not working, how do I reset
The remote buttons still work, but the display is blank; so I have to work it using my memory of which buttons are which. How do I reset it and get the display to work again? Batteries are new, it is not a battery problem.
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
If that does not get the screen working, then it is something with the hardware that is defective. If this is the case, I would email Logitech.
Posted on May 08, 2010
Why is screen blank?
You never said if it worked with external monitor. You also didn't say if you tried the [fn]+[Fx] key combination on the keyboard to try and switch displays.
But, if you look at the screen closely, at an extreme angle and can faintly see the graphics then that means the backlight has blown out. For the displays with LED backlighting it's usually just a wire or circuit to repair. For the screens with CCFL (fluorescent) lighting it's a simple matter of replacing the inverter board.
Mar 14, 2016 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Ca900 radio wont work - the radio lights up as expected but the main area that normally displays what station yo are listening to is blank. No sound comes out except from the beeps when pressing buttons on...
Hello Dan, have you tried to reset the unit using the reset button behind the front panel? also try to clean the panel metal contacts, clean them using a cotton swabs or an handkerchief wet with alcohol, both side (main unit & detachable panel)
Oct 23, 2013 | Car Audio & Video
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
Touch screen display broken
HI! Here's what to do if your Logitech Harmony remote's LCD screen has gone blank.
If the screen is still blank after you complete these steps, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty. If you are not in warranty, Logitech does not provide repair services for Harmony products.
Hope that helps.
-D
Aug 26, 2009 | Logitech Harmony One Advanced Universal...
Programing a new remote
Use these instuctions if your Deville has an Analog Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Panel (CCP) simultaneously.
(Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode.
Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP.
If “RFA DATA” is displayed, press FAN DOWN.
If “RFA OVERRIDE” is displayed, press FAN UP.
2. If “RFA 500 NO OVERRIDE” is displayed, press FAN DOWN.
If “RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP.
3. IPC will show “0” on right side of Driver Information Center (DIC) display.
Press warmer button on climate control unit until “99” is displayed.
4. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not
programmed within 30 seconds after entering “99” override display, system will default and you must begin again at
step 2.
5. To program a second remote, press FAN DOWN button until “RFA 502 PROGRAM FOB #2” is displayed, then press
FAN UP. Repeat step 4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will
light all telltales, go blank then enter DIAGNOSTIC
MODE. Press FAN DOW button to scroll through system until
“RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then
press FAN UP button. When “NO OVRD RF 500” is displayed, then press FAN UP button.
2. When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just
below odometer. System is now ready to program remote.
3. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
step 2.)
4. To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to
program second remote.
To exit system, press RECIRC or RESET buttons.
Disclaimer
Apr 25, 2009 | 1998 Cadillac DeVille
Remote won't work
Using a small test meter, check that you have 1.5v on each battery. Sounds like faulty batteries.
Mar 14, 2009 | LG Heating & Cooling
Remote won't work
The remote stopped working. So I changed the batteries Then remote signal's are OK But Indor Unit is not controlled by remote.
Feb 01, 2009 | LG LSC121PMA Split System Air Conditioner
Logitech Harmony 670 LCD Remote Control Logo
1,019 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
