We have a front load duet washer. it will stop
We have a front load duet washer. it will stop and sud comes on the screen. I have to keep turning it off and on to complete a cycle, the washer beaps until you turn it off an on
  • 5,911 Answers
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you. Read through the link provided and let me know if you still have questions. I hope this helps you.
Posted on Apr 24, 2010
S6 mean on my duet washer
1) this means overcurrent by the motor,the controller sense SUD detected. Indicating bad pump, or extra heavy load,excessive detergente, or SUDs. Press STOP/CANCEL for clear the display
God bless you
Jul 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water keeps running through every cycle of my Duet Front Loader.
You most likely have a bad water fill valve. The suds warning is likely because it is too full.
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sud code comes up and stops and just beeps
Are you using HE detergent (for all front load washers ) or regular detergent ? SUD means suds lock from regular detergent .
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer will not complete a cycle.
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up.. be sureto use HE detegent this will eleminate "suds"
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Suds on display screen
run washer with no load or detergent to be sure no suds remain use HE detergent only..if you are suds is not an issue remove lower panel and clean pump ..turn white knob counter clockwise ..electronics can get confused sometimes too
Jul 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
