Question about Linksys WRT300N Wireless Router
After i touched the reserved button, the router stopped working.
The model i got is Linksys WRT300N. After i touched the reserved button, it suddenly stop working and the light is just still. what can i do to rework the router?
  • 550 Answers
Did you press the Reset button on the router ?
If you press the reset button then the router will come back to the factory default settings. You will need to reconfigure the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 01, 2010
    President:
  • 1,768 Answers
You have probably put the router in standby mode.
After i touched the reserved button, the router st - moz-screenshot.pngcheck the manual for factory reset.
page 6
Posted on Apr 26, 2010
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
What is the reserved button for?
The button at the top panel is for future function.
Dec 09, 2009 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300n will only allow local access wirelessly
go into the router interface and see if it is set for DHCP and reboot systems it should be fine
Jul 17, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
WRT300N dosnt connect
if your connection (isp) is CABLE you will need to clone the mac of the main computer.
For cable connection verify what computer can go online with your modem, once you know the main pc connect it to port one, access the routers setup page by typing 192.169.1.1 then locate MAC ADDRESS CLONE in line with basic setup. enable it click the macclone button then save settings.
connect your modem to the internet port on the router, do a power cycle on the modem and router.
then check the status tab on the linksys setup page if you have numbers on the dns it should be online.
Sep 12, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
1,499 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
