Question about Nordic Track Nordictrack Futura 2200 System NTS5874
We have a Nordictrack Futura 2200 and when we set the weight resistance it jumps back to 10lbs. no matter what we set it for it jumps back to 10lbs
    President:
  • Nordic Track Master
  • 832 Answers
When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If the motor has difficulty adjusting the resistance level and no cable is being pulled, there may be too much tension on the Upper Cable (110). Adjust the tension as described below. To decrease the tension on the Upper Cable (110), turn the two 3/8” x 38mm Tension Screws (106) twice, counterclockwise. Select the desired resistance setting. Repeat this step if necessary.
Posted on Apr 24, 2010
NordicTrack RX800 Rower has no resistance even when set to 10.
If you wish to get some details; visit the site linked here. Pull up older posts.... http://electro-medical.blogspot.com/
Jan 08, 2017 | NordicTrack Exercise & Fitness
Just bought a nordictrack audio strider 900 every thing works OK a part from the resistance . Go to alter resistance and nothing changes Any ideas as to why Kind regards nick
the resistance is done by a magnet and a motor that moves it closer or farther away from the flywheel. possible the motor is bad or not adjusted properly
Jan 30, 2016 | NordicTrack Exercise & Fitness
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
About 90% of records i play on my t.92 play perfectly fine. But some records get constant jitter and skips. I've tried to set the anti skate to compensate but it seems like it doesn't even work at all no...
Assuming the records are NOT faulty, then the problem might be the set up of the deck. The way to do this is to get one of the skipping records and set it for playing. For the moment set the anti skate to the neutral position or off. If the record is jumping, take it off the record and turn the weight control (on the end of the arm) up slightly just a touch. If you check out out the specifications of the cartridge it should suggest an ideal weight setting for it. If you like you can start with that, before making any more adjustments. If you are starting with the ideal weight and it still jumps, increase the weight by a slight amount and test the record. You keep doing this till the record stays in the groove, but does not rumble. I find headphones ideal for this testing. If it does rumble the weight is too much.
It's a slow process but it's the only way really. You can set the anti skate control after you have got the weight right.
But a slightly worn stylus and a bit of dust can cause a record to jump, but not on all records. Some records are also better made than others too, so would be more sensitive to the wear.
Mar 17, 2015 | Stanton T.92 USB Turntable
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
3Q) How can I decide which level of spring resistance to use?
The important thing it to make sure that you don't use a spring that is designed for someone under your weight range. This will wear out the springs and pads, and can cause damage to the stilts and injury to yourself. On each box, there is a scale so you can find your weight range and match it to the correct spring. If you want to jump extra high, you can choose the spring for the weight above your weight range. This spring will have more tension and allow you to be propelled farther from the ground
Dec 25, 2012 | Sport & Outdoor - Others
In long jump does it matter how high we jump? what factors determine the span of jump?
When jumping bikes, at the minimum, you need to consider, velocity, height, weight, and trajectory.
The optimium trajectory for the longest jump is 45degrees.
Aug 19, 2010 | Cycling
Free manual for nordictrack model ntl 1192-0
google Free manual for nordictrack model ntl 1192-0 or call nordictrack. I can usually find a ny manual I need by googling .
Oct 22, 2009 | Nordic Track Nordictrack Futura 2200...
Weider platinum xp800 gets locked in maximum weight position
open the housing in back of unit and manually turn the bar (top left)next to pulley motor until the resistance bar is all the way to the right or in the lowest wieght setting. make sure to put the weight on the console to 10lbs. now plug unit in and press and hold the next button and the + on the wieght selector for five seconds then press the + again on weight then next one more time and this will recalibrate the machine, unplug and plug back in and ur ready to go.
Aug 09, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Nordic Track Nordictrack Futura 2200 System NTS5874 Logo
187 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
