Monitor flashes on and off incontinuesly for about five minutes before the power finally stays on and then the monitor functions ok. This happen when the computer has just been turned on from the sleep or off mode. If not using the computer for 'X' amount of minutes and it goes into a sleep mode you can depress the space bar to reactivate it and the monitor powers up ok in that situation. What could be the problem?
This is a classic symptom of a failing power supply. After 2-3 years of use many LCD power supplies will start fail because of parts called capacitors that start dying due to the heat buildup in the monitor case. If you can solder then you should be able to do the repair yourself. Check out this page on our web site; http://www.ccl-la.com/blog/index.php/capacitors/ This article explains what capacitor are, how they fail and what you will need to get for the replacement parts. The parts can be ordered from many places on the internet, we stock they too. If you don't want to do the repair yourself we do offer a repair service, that info can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps you, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
donco1937, Your lcd display may have problem if it only happens (on/off/on/off/on/off) during the initial first turn-on of the day when unit is same temperature as the room where unit is used. Unit may have developed one and one only "thermally-intermittant" solder connection of a passive or active electronic component to the copper trace to which it should be solidly attached!!! Once the unit is warmed-up to operating temperature (5min of on/off's) the printed circuit board will "warp" (contort) slightly and now the intermittant connection will become "closed" and unit will now operate consistantly. Turn off lcd display, let it cool back to room temperature (2-3 hrs) and same thing should happen. Try blowing warm air from hair dryer into unit's vent slots on rear side before turning on the unit to see if 5min of on/off's decreases to 1 or 2 min of on/off's when unit is in "cold state". DO NOT HOLD HAIR DRYER CLOSER THAN 12 INCHES FROM UNIT!!! Let us know results of testing. 12fixlouie
