Have a sharp tv its a LC-150M2 and it dont have a TV tuner thing but would like to know if i can set it up with out it
  • kmax031 Apr 24, 2010
    thank you
  • 10,865 Answers
Hello. Yes you can set it up if you use a video recorder as your tuner. Joe
Posted on Apr 24, 2010
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: http://www.crutchfield.com/S-4LS7pNsldXK/p_70037G4U/Sharp-LC-37G4U.html . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: http://pdf.crutchfieldonline.com/ImageBank/v20040615154800/Manuals/700/70032G4U.PDF .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Dec 06, 2011 | Televison & Video
SHARP LC-37SH20U GREEN LIGHT BLINKING BLANK SCREEN NO SOUND HAD A POWER OUTAGE & NOW IT WILL NOT TURN OFF UNLESS YOU UNPLUG FROM POWER SOURCE & IT WILL NOT GIVE PICTURE ABOUT 2 YEARS OLD CALLED...
The tv Tuner signal board is it shorted and the caused,that the board where ur tv signal cable wire plug in for tv broadcasting air tv stations.This tv Tuner signal board must be replaced,u can do it if u some basic mechanicals skills like take things aparts and putting it back together again?Yes?U tries websites like Shopjimmy.com,Ebay.com to buy a whole tv refurbish tv Tuner signal board for the replacement.Or must get a priced quote by tvs repair shops,replaced an repair by thems.
Jul 26, 2011 | Sharp LC37SH20U 37 in. LCD Television
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharpe aqous runs for so long then a message appears saying the tv will automatically switch of in 5 mins, this appears every minute until the 5 mins are up. I have checked and the sleeper timer is set...
Tries unplug,replug tv an hour later.Let the tv reset itself.Than goto tv Menu go to PICTURE,go down to reset.This will reset everything on the tv Tuner board back to factory setting.This should solved ur problems.Not,than the tv Tuner board have intermitten isuse problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 13, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Pls help me, my sharp lcd driving me nuts, everytime i on it, it turns to standby in 2-3 secs, leaving me with no way to even changes its settings in the menu.
Unplug the tv about an hour,replug it back,the tv should be back to factory setting.U can do what ever in the menu than,not than the Tuner board that the board that take in the coalax cable hook in to take the comming broscat signal.That the Tuner board,must change it have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jun 09, 2010 | Sharp LC-32AV22U 32 in. LCD TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
Need power cable for SHARP LCD TV to use in Turkey
It is not the power cord that makes the rating of the power supply. You can use a transformer, and not a solid state converter to lower the 220 V to 120 V.
What you will find if this is a North American TV set, it may not work in other countries due to the standards for TV broadcast.
If the set is rated for PAL, this will only work with the video inputs, and not the tuner. The tuner frequency allocation and the video and audio carriers are also different between the some of the different countries.
Jerry G.
May 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
