Question about GE JES1290 Convection/Microwave Oven
Where is the fuse located? - GE JES1290 Convection/Microwave Oven
  • 5,911 Answers
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Posted on Apr 24, 2010
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
Where is the thermal fuse located at on kenmore microwave model 665
Depending on the total part number 665xxxxxx a replaceable fuse is located behind the control panel usuallyon the floor of the control cabinet.
on one specific model "not yours" to check out the fuse locations a part number 309796 was found and I've included an image. Values of the fuses change based on specific models.
A typical location is included in the following image.
26047724-i5ybdsgcpm55v0g4hkv2rsri-5-2.jpg During previous repairs the fuse holder has failed and has required repair in addition to the fuse being replaced. This work needs to be accomplished by a qualified repair person. Even with power remove voltages remain because of stored engergy in the capacitors.
Hope this has been of help?
Jan 10, 2016 | Kenmore Microwave Ovens
Where is the fuse for delonghi mw 605 located
Wich fuse?
High voltage is located on transformer, low voltage above fan. You need to remove case.
Oct 10, 2014 | DeLonghi Microwave Ovens
The fuse is generally located very near where the main power wires. It is most likely located inside so the lid must be safely removed and the unit must be unplugged. The power wire will run directly to the fuse in a block. Replace with the same size and type.
Sep 21, 2012 | Goldstar MA-1012 Microwave Oven
Whirlpool gold YGH5184XPS-0 fuse location, I believe i blew a fuse and cant find the location, the thing worked fine and then i shut the door and lost all power, either the door latch is broken or the...
Mike - Unplug the unit and unscrew about 4 screws on the top and then the side panel and the fuse will be in that location.
Note: If the fuse looks brown, it's definetly blown, you can get the same fuse at your local Radio Shack for about $0.97. hope this helps
Aug 14, 2012 | Whirlpool Microwave Ovens
Where are the fuses located on a samsung electric range oven FTQ3521WW model #
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave.
In general you can locate the internal fuse by opening up the microwave cabinet. To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Jun 01, 2010 | Westinghouse WST3504 Microwave Oven
Cooks Model 2115 microwave oven will not power on when connected to the 110v outlet. Can this be a fuse problem? If so, where is the fuse located?
Yes, is probably the fuse. I have fixed several microwaves with this problem and the fuse is almost always located just inside where the power cord enters the unit. Just remove the skin (usually screws on the back and BOTTOM also) test the fuse with a micro meter. If no contenuity, replace with same size, type and rated fuse. Most microwaves are 20amp fuse.
Jan 19, 2010 | Microwave Ovens
Microwave Model 87720 fuse location
Almost all models have the fuse located under the control panel .Should come off with a couple of screws but careful with the ribbon. Hope this helps
Jul 30, 2009 | Kenmore Microwave Ovens
GE JES1290 Convection/Microwave Oven Logo
220 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
