Question about Denon AVR-687
I dont know how to hook up my 15 band2 channel ross system eq
I have ross systems R-15S 2 channel 15 band eq , i want to hook it up to my avr687 denon receiver, my 2 channel eq on the back it has the rcas chanel 1 unbalance output , balance output, and balance/unbalance input chanel 2 has the same as chanel 1 what do connect to my avr 687 denon receiver so i could use both channels and to what on my receiver . i have to hook it up today any tips are highly appreciated thank you
4 Suggested Answers
  • 2336 Answers
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Posted on Jun 20, 2008
  • 11 Answers
SOURCE: No system configration display on AVR3300 since moving.
Make sure the two switches on the remote are all of the way to left most position before you try using the SYSTEM SETUP button - if the AVR is going into SETUP, the LCD display should be saying "SYSTEM SETUP". (I think that model does - most do).  also make sure that the Composite or S-Video on the TV's input 1 work from something else like a VCR, DVD player, ETC. rule out the TV and the cable first.
Posted on Apr 02, 2009
  • 547 Answers
SOURCE: im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Posted on Apr 15, 2010
Testimonial: "thanks alot very helpful"
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
Can i hook up an amp & eq to a denon avr3805 if so how?
What are you doing with the extra amp? You can use it as a preamp by connecting a 5 or 5+2 channel amp to the Pre Out section witch RCA cables. If you just want to adjust the EQ of the right & left, put the EQ between the two. If you want to EQ all channels, you'll need 3 equalizers. Isn't 120 watts per channel enough? If you don't have it already, download the owners manual from Denon Support Site.
May 12, 2014 | Audio Players & Recorders
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
I hooked up equalizer to it through tape hook up but will not work
Even if you DO get the EQ connected correctly (hint: out go to ins) it will only work for analog 2-channel sources if engaged. AND any digital sources will be disabled.
Jul 10, 2011 | Denon AVR-483 5.1 Channels Receiver
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
HOW can i connect this ross model eq r15s to my avr687 denon rece
Treat each EQ (or any processor) as as Tape Deck and place it on its own Tape loop on the Denon. Tape deck(s) can attach to external processors because they always have tape loops to replace the one they use.
Rule of Thumb: OUT's go to IN's.
You can have as many processors as you want. I have five.
You can serialize processors if they would logically be used together or you could get a dbx-200 or dbx-400 Program Route Selector which provides connections and switching facilities for 3 processors and 3 tape decks but uses only one tape loop on the receiver.
Individual processors can be engaged or disabled, and the whole mess can be placed in the record OR the playback end of the chain - all via front panel switches. Very versatile.
Apr 21, 2010 | Audio Players & Recorders
Im trying to connect a bsr xr eq to my avr687 denon receiver
Apr 15, 2010 | Denon Audio Players & Recorders
Eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Apr 14, 2010 | Yamaha EQ-70 Home Equalizer
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
Denon AVR-687 Logo
48 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
