2000 Ford Windstar Logo
Anonymous Posted on Apr 24, 2010
My right front tire makes a squealing noise from
My right front tire area makes a squealing noise from 40 kmp and on. as you drive faster it gets louder but gets quiet when slowing down. sometimes its there and sometime its not. sounds like something is rubbing together, and when it rains doesnt squeal at all. it sounds like when your bike tire isnt true and the rim rubs against the brakes only it is a squeal. 2000 ford windstar 173000km, any help will be great. thank you for being here
Anonymous
Level 3:
Brigadier General:
  • Master 4,669 Answers
  • Posted on Apr 24, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4669
Questions
0
Helped
1847214
Points
16674
First the tire pressure is at 35 right? Next, have you had the alignment checked?
Anonymous
Level 3:
  • Master 524 Answers
Anonymous
Master
Level 3:
Answers
524
Questions
Helped
213850
Points
1468
That sounds to me like your brake pads may be dragging or your wheel bearing is shot
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
3answers
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Hearing a pinging and squealing noise from the left front tire on my ford 500
Power steering pump may be making that noise or the belt is loose.
2answers
I have a roaring sound coming from the front end of my f150
sounds like the cooling fan clutch to me, look under the hood next time you hear it, will be easy to confirm if that is the noise.
Just Got A Honda Prelude What Do I look For?
Take a look at the cv joints....the boots that cover the ends that go into the tranny and the end that attaches to the tire area. Look at the color of the oil...see if it is grey or tainted with anything other than motor oil.
Take a look at the belts....cracks fraying, shredding....is the belt tight....that type of thing for the belt inspection....look for shiny spots...leads to squealing.
Drive the vehicle at different speeds....you're paying attention to the "feel" of the steering...this will give you indications of the front end....it pulls left, it pulls right.....wobbles....make turns left and right....listen for clunks....all this will let you know the condition of the front end/steering system.
Get on the highway or open road.....drive about 45-65 and slow down faster than usual...if it pulses in the front end, and you can feel it in the steering wheel...good bet the rotors are warped from high speed braking. Squeeks when you apply breaks....brake wear indicator telling you the brakes are worn.
Jack the front of the car up and twist and pull...push and pull the left and right tire....anby wobble or noises...may have bad bushing/ball joints/cv joints.
there is a lot of stuff to look for...but this is a few things to keep you busy.
Hope this helps you.
Please don't forget to rate.....Thanks
2helpful
Front right wheel noise
try driving at 40 and turn left then right back and fourth if its a wheel bearing it should get louder as you turn your steering wheel back & fourth if not it may be a tire you may want to rotate front to rear
2answers
Thumping at front passenger wheel area
if the noise isassociated with "wheel speed" then it is in the rolling parts... axle hub bearing brake rotor caliper wheel or tires...if it goes away on right turns then you are unloading or separating the issue then...so a hub /wheel bearing /axle issue is most likely...does your brake pedal pulse when you feel it..(riding the brake while driving)..does the steering wheel shimmy ?
2helpful
Rumbling in front tires
You probably have a bad wheel bearing or bad tire on left front. when making right turn left front wheel wil spin faster than right making noise louder.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
