Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My touch control pad does not respond to my touch.....What's up with this? Thanks for the input. Edmon from 'Bama
  • Fisher and P... Master
  • 713 Answers
Worked on these dishdrawers alot. problem is nearly always the control module. if u need help to replace it please reply.
Posted on May 05, 2010
    Problem Solver:
  • 6 Answers
Sometimes simply cleaning & drying the touch pads does the trick.
Posted on Apr 30, 2010
  • 523 Answers
The lights on the panel show the error code
Posted on Apr 24, 2010
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
How do I turn off the touch tone on the key pad?
Go to settings.
Language and input.
Keyboard and input methods.
If google keyboard is your default, tap on the settings image.
Under General, there is an option called "Sound on keypress".
If checked, un check it and the sound will disappear.....
Sep 18, 2014 | Dell Venue 7 or 8 Tablet in Black
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
F 22 just appeared on my washer. I tried restarting it and it made a clunking noise every 5 seconds and then f 22 appeared again. What does f 22 code for? Thanks,
F-22 is: CCU /touchpad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Your model's tech sheet gives error codes and remedys.
Duet HE manual and more HERE
Jan 22, 2011 | Kenmore Elite HE5t Washer
Savannah Spa Sunset Dlx control pad doesn't respond
What does it mean when the word SPA comes up on the control pad window and locking up the control pad.
May 23, 2010 | Aqua Pool & Spa
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Washer goes right to drain when started
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
(CCU).
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Touch Temperature Controls not working
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Apr 09, 2006 | Amana ABB1927DE Bottom Freezer...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
467 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
