Question about PC Chips (M791G) Motherboard
Disk not deteceted
HD not detected, tried several different disks and IDE cables. American Megatrends AMI BIOS 2004
  • 1,557 Answers
Is the jumper set correct to master or slave?
Posted on Apr 24, 2010
Bios keeps booting, no hard drive found
AUTO search harddrive will not detect the harddrives in the bios list but loads by position priority by the used bus the first ide or sata set it to manual in the page where you see auto by double click or older machines by tab and + - or arrows its depending on the brand of the bios. ami or phoenix , dells bios building by separate companies or award or somewhere . first release the battery a minute and replace if its empty if you have no booting harddisk if you have only 1 ide harddisk the are sometimes neccesary by different jumper settings to set it for the single drive only instead of master or slave with the one jumper setting for master on the end of a ide cable and the slave on the second drive both on one cable in ide pos 0 the hoighest priority look on the drive self or on internet that your bios will see the brand in the bios and info of the used hard disk.
single drive only jumper setting Google zoeken
Jan 02, 2016 | Dell Computers & Internet
I may have erased BIOS on my Maxdata eco 4000a laptop. Can it be restored?
Your problem is the boot sector on the hard drive has become corrupt. Nothing to do with the BIOS.
Find yourself a hard disk utility and check your hard disk integrity.
Low level format your drive and reload your Linux
May 02, 2014 | Computers & Internet
Will hdz965fbgmbox processor work with ami po1-ao mobo
AMI is American Megatrends Inc.
A BIOS program company. (Basic Input/Output System)
AMI po1-ao is one of AMI's BIOS programs.
Used on a LOT of desktop computers, and consequently several different motherboards.
How about the motherboard manufacturer, and model number; or computer manufacturer, and model number? Model number is on the back of the computer next to the Windows product key; or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Nov 27, 2012 | ATI Amd Amd Phenom II X4 965 Black Ed. -...
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Kob 740 ESC mainboard bios can not detect more than 99 gb of HD
What is your file format? FAT32 wont detect much Space. Try NTFS if not using. You should get the bios update on the site of manufacturer.
Apr 03, 2009 | Computers & Internet
Slaving my hard disk
hmm..
it's hard to put it on words, but ill try my best.
1st Inserting and removing the IDE cables and power cables :
- 1st of all you should know how to insert the IDE cables and power cables, but before you remove the cables and put it back again, try to observe the color of the cables, the Red color of power cable is parallel to the red color of IDE cable. so when you insert it again, you put it on the same way, the Red color of each cable must be parallel.
2nd putting the jumper:
- try to check the printings on you hard disk at the bottom, and see if there's any tutorials on how to put the jumper.
3rd access the BIOS:
- to access the BIOS, click Del. Hence, before you modify any settings there, MAKE SURE to remember those settings that you modify, so that when there's a trouble you can put it back to it's default setting. Ok let's continue, if your BIOS has an auto-detect it will directly detect the Hard Disk drive that's being installed, if not you will manually detect it on the different Hard Disk setting. After modifying save and exit setting and reboot your PC.
i hope this helps you.
Oct 31, 2008 | Computers & Internet
Setup pasword
are you able to start the pc and boot dos for example?
if you can start the pc with a windows 98 startup disk for example
you can get the bios reset with debug program, if its not on the startup disk you need to get it online.
you can get a bootdisk here
http://www.bootdisk.com/bootdisk.htm
and the debug if not on the disk from your windows xp for eample.
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer.
If you can't start up.
here are some backdoor passwords to try
American Megatrends BIOS
AMI, A.M.I, AMI_SW, aammii, AMI!SW, AMI.KEY, ami.key, AMI~, AMIAMI, AMIDECOD, AMIPSWD, amipswd, AMISETUP, BIOSPASS
Award BIOS
?award, awkward, award, award_?, award.sw, award sw, AWARD_SW, AWARD SW, admin, alfarome, aLLy, aPAf, BIOS, biosstar, biostar, CONTACT, condo, CONDO, g6PJ, h6BB, HELGA-S, HLT, j09F, j64, j262, j256, j322, lkw peter, lkwpeter, LKWPETER, PASSWORD, SER, setup, SKY_FOX, SWITCHES_SW, Sxyz, SZYX, t0ch20x, t0ch88, TTPTHA, TzqF, wodj, zbaaaca, 1322222, 256256
Phoenix
phoenix
SystemSoft PnP BIOS
system
manufacturer preset ones
VOBIS & IBM: merlin
Dell: Dell
Biostar: Biostar
Compaq: Compaq
Enox: xo11nE
Epox: central
Freetech: Posterie
IWill: iwill
Jetway: spooml
Packard Bell: bell9
QDI: QDI
Siemens: SKY_FOX
TMC: BIGO
Toshiba: Toshiba
Jun 14, 2008 | HP Pavilion dv4000 Notebook
Weird error message on boot. BIOS error?
This is a strange one. Does the BIOS on your motherboard detect your hard drives at all? I'd try the lowest level first. If so, then try to boot from your XP CD ROM (hopefully this should work). Try to go into recovery console to see if your hard drive can even be mounted by the system. I'd check there.
If you still have issues,try to reflash your mobo BIOS to the most current one. Could be a flaky BIOS issue.
Feb 06, 2008 | AMI American Megatrends UltraSCSI...
PC Chips (M791G) Motherboard Logo
65 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
