Question about John Deere Tractor 50, 60, 70, ITJD10
John deere 60 power steering occasionally locks up. Must turn wheel opposite way to free it up. It does it in both directions when the oil is hot or cold. I have completely disassembled and reassembled it according to the factory john deere manual. The problem still exists. Need Some advice.
SOURCE: I need a wiring diagram for a john deere 550
get a pic of the tactor first
Posted on Apr 26, 2009
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 2976 Answers
SOURCE: Radiator water in oil of my John Deere 310A
You have either a blown head gasket, cracked block or craacked head. Major work ahead. Hopefully, the water didn't mess up your main bearings.
Posted on Sep 01, 2009
SOURCE: John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Posted on Oct 17, 2009
  • 12104 Answers
SOURCE: my John Deer 1020 turns fine to the left but when
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Posted on Oct 30, 2009
Haudraulick problems on John Deere 3350
Try disconnecting a hose from the steer cylinder. Place the hose end in a 5 gal. bucket and see if you have flow from steer motor. turn steering wheel to the opposite direction of open hose fitting to check for steer cylinder piston leakage. Piston leakage will pressurize both directions of steer cylinder at the same time resulting in no steer. Be careful not to overflow your bucket. Reuse your oil if bucket is clean
May 21, 2017 | Cars & Trucks
Does anybody know why steering column doesn't lock on a 5325 john deere tractor?
Its likely worn out.The key switch could be working fine but their is a pin that locks the column spring loaded that maybe worn or damaged or the column tube that receives the pin .
As long as it runs OK and the steering wheel turns its not going to effect anything else but the steering lock .
Oct 28, 2016 | John Deere Garden
Why do the wheels run backwards?
the spray bar nozzles can be adjusted to spin the head clockwise or counter clockwise if the wheels run backward rotate the nozzles so the water pressure turns the head in the opposite direction which will then drive the wheels in the opposite direction..
Aug 11, 2013 | John Deere Gilmour Traveling Sprinkler -...
Jd 60 w/power steering. while turning the tractor the steering binds and is very hard to unbind and steer. It does this in all directions.
Look for a nut with a screw driver slot in the middle of it -
Put a wrench on the NUT shape and turn it to the LEFT or counter clockwise. - then turn the SCREW DRIVER SLOT to the LEFT -or counter clockwise.
Then re-tighten the NUT shaped unit by turning it to the RIGHT/
Gary @ Fix Ya
i
Jun 16, 2011 | John Deere 50 60 70 520 620 720 Power...
My John Deere traveling sprinkler is in reverse and can not make it go forward. Help its hot outside. Thank You!
Improperassembly. Change the direction of the nozzles on the spray bar so it turns in the opposite direction..
Apr 22, 2011 | John Deere Gilmour Traveling Sprinkler -...
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Tractor 50, 60, 70, ITJD10 Logo
168 people viewed this question
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
