Question about ViewSonic N3250W Television
Viewsonic N3250W- turns on, the screen flickers on then its black
The sounds is stays on. Any ideas would be apprecitated.
  • mikehammo Apr 24, 2010
    Thanks Cindy for the prompt response, however unfortunately, the screen flickers for one second and goes black, nothing can be seen on the screen afterwards, as if it is a power issue, I think.
    Mike
  • mikehammo May 10, 2010
    I orderd the inverter board from shopjimmy.com and replaced it, and that did it. Thanks everyone for your support!
  • ViewSonic Master
  • 5,380 Answers
This could be a problem with the tv's memory. Try resetting the TV. Unplug the unit for a few seconds (10-60). Then restore the TV to the factory default settings. Viewsonic has changed it's menus at intervals so you may have to check your manual. It may be Menu > Setup > Memory Recall or Menu > Options > Restore Default (or something slightly different). From there, click enter, use the right or left arrow to select YES, hit enter. Leave the menu system (Menu twice). Then hit Menu > Channels and rescan all channels.
An alternative cause of the problem may be a weak signal - check that your antenna is pointing right at the station and is the correct type to get the signal at the distance you are from the station. (Usually a weak signal would also have the audio breaking up but weird things can happen.)
I hope this helps.
(who recently had a channel pair that started out with flickering signal issues and then had one channel lose video and the other audio. The memory reset and rescan resolved the problem.)
Posted on Apr 24, 2010
  • Cindy Wells Apr 24, 2010
    Sorry about misunderstanding your issue.
The volume won't stay at the level selected. It counts itself down to 00. I hold the volume button to raise the sound but it struggles to go back to 00. The highest setting goes to 03. I have no...
Remove the TV from the power for a few minutes, and then power on, then check the volume, effectively you have reset the set. If it still will not work, check the manual for any sleep settings etc, and work through the setup again for the channels. Now if none of that works, and it isn't a remote control issue? Then unfortunately you indeed have a problem with the set and it will need to be serviced. it will most likely be a microprocessor and ambient background noise sensor or the like, this will have to be replaced. To this end get a "Quote" from a certified repairer, and go from there?
User and service and repair manual at links below....should you wish to DIY?
http://www.retrevo.com/support/Viewsonic-N3250w-TVs-manual/id/276ag810/t/2/
http://michaeljaylissner.com/archive/viewsonic/n3250w-1_sm_1a.pdf
Oct 07, 2011 | ViewSonic N3250W Television
I have a viewsonic n3250w that won't turn on. where do I start?
Unplug the TV from the wall outlet. Press and hold the power button for about 10 seconds. Wait five minutes and then re-apply power.
Nov 26, 2010 | ViewSonic N3250W Television
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
Viewsonic N3250W I replaced the power supply board but when I turn on, the screen flashes real quick and there is no picture.
it was not the power supply its the invertor board that controls the back lighting/switch on screen flashes lights go off/shine torch into screen ull see picture/get new invertor board 7 or 8 little plugs go into it
part or repairs in uk ohm supplies
Jan 08, 2010 | ViewSonic N3250W Television
N3250W: Sound w/ no picture.
you may have a bad inverter board. check for 24volts to the board.
Dec 30, 2009 | ViewSonic N3250W Television
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Jan 28, 2008 | ViewSonic N3250W Television
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
ViewSonic N3250w has black line
Unfortunately, my experience with LCDs says that when you see something like this, it usually indicates that the LCD screen is cracked. If you press gently in the area of deformity and it goes clear then returns to black when you remove pressure, it's a tell-tale sign of a cracked screen. Go to e-bay and see if you can get a replacement screen if you're mechanically up to changing it yourself, else an electronics repair shop might be your only hope.
Dec 08, 2007 | ViewSonic N3250W Television
Televison & Video Logo
612 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
