Systems properties,click on system restore.the display says:drives c & d turned off.but you cannot turn them on from this box that you are on [system restore] please why? & how can i change this to let me do a system restore.
  • Colin Taylor Apr 24, 2010
    HI M8,thanks for your time but i had no joy with that,colin.
  • 4,924 Answers
To get to the system restore for sure ..get to the control panel ... be sure it is switched on category view...and than click the maintenance and performance...in this moment in the left side task bar you will have the initiation of the system restore......BUT!
if the system was turned off until now..you will not have any previous point to get back to ..so ..what you have to do is turn in on and you will have a point from now on...and a point will be made each time you install or uninstall anything ..
you can also turn the system on ...by right click on my computer icon...choose system restore...and uncheck the case that says turn off he system restore..I actually believe it will be possible to turn it on from both ways..
Have a nice day ..and dont forget to rate ...!
Posted on Apr 24, 2010
  • Catalin Turcu
    Catalin Turcu Apr 25, 2010
    yeah...I can understand that you expected to solve some issues by restoring to a previous dat ...settings..but I have no fault that your system was not turned on ...by default when windows is installed the system restore is turned on ...so ..if it is turned off..you have all the blame or the person that turned it off ..iF you have serius issues caused by viruses..its better anyway to reinstall it clean ..Just save all the important media and documents into another partition but C and reinstall and format the C partition again ....This will take care of all bugs and wrong settings and give you a clean start..
TS-L633A firmware update
Follow these steps to resolve your cd dvd issue. It's mostly caused by an error in the registry.
Before you proceed, create a backup of your registry.
Manual steps to back up the registry in Windows XP
1. Click Start, click Run, type %SystemRoot%\system32\restore\rstrui.exe, and then click OK.
2. On the Welcome to System Restore page, click Create a restore point, and then click Next.
3. On the Create a Restore Point page, type a name for the restore point and then click Create
4. After the restore point has been created, click Close.
Note If System Restore is turned off, you receive a message that asks whether you want to turn on System Restore now. Click Yes. Then, in the System Properties dialog box, click to clear the Turn off System Restore check box, click OK, and then repeat this step.
The next step is as follows:
First and foremost, go to My Computer; right click on properties, hardware, and then Device Manager.
Right click on the CD DVD drive and uninstall it, then click OK, then close.
Next Step:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
Jun 28, 2012 | Samsung TS-L633A DVDRW R DL drive - Serial...
Tip
How to back up the registry in Windows XP
  1. Click Start, click Run, type %SystemRoot%system32restorerstrui.exe, and then click OK.
Note: If System Restore is turned off, you receive a message that asks whether you want to turn on System Restore now. Click Yes. Then, in the System Properties dialog box, click to clear the Turn off System Restore check box, click OK, and then repeat this step
on Mar 03, 2010 | Microsoft Windows XP Professional
My on screen display has gone small
What do you mean has gone small? You mean your icons are smaller?
Try changing your screen resolution. Right Click on an open space on the desktop and select Properties. When the Display Properties window opens select the Appearance tab. Look down at the bottom and you can make sure your Font Size is Normal, if not change it to Normal. Click the Settings tab and change your screen resolution. The higher the resolution, the smaller the icons. Size 1024x768 is what most people use.
You can also get to the display properties to perform the steps above by clicking Start/Control Panel or Start/Settings/Control Panel. Look for Display or Appearance and Personalization. Open it and the display properties window will open.
If you are using Windows 7 you can also just click Start and in the search box type Screen Resolution. Look up at the top for the search results and click on Screen Resolution.
If you can't get it back to the way it was you can try doing a System Restore. System Restore allows you to select a Restore Point (date and time) before you started having problems. So if you display went small yesterday, then select a restore point before yesterday.
System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). To start System Restore click Start/Program/Accessories/System Tools/System Restore then select a data and time before you started having the issue.
If you are using Windows 7 you can just click Start then in the search box type System Restore and look up at the returned search results and select System Restore.
System Recovery on the other hand deletes everything and sets your system back to when your first purchased it.
May 20, 2012 | HP Computers & Internet
How do i disable windows restore
Steps to turn off System Restore
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the System Restore tab.
  3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
  4. Click OK.
  5. When you receive the following message, click Yes to confirm that you want to turn off System Restore: You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
    Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
Jan 11, 2011 | Microsoft Windows XP Professional SP3 Full...
I have a 5yr old Dell w/XP and use IE and Firefox. Lately I have been unable to access my control panel. I click on start then click on control panel but all I get is the ever aggravating hourglass and...
Here are a couple suggestions. 1.) You can run windows system restore back to a date when you knew your system was running fine.
If that fail to fix your problem than, turn off windows restore. You do not need to enter control panel to do this as long as you have My Computer icon sitting on your desktop. (IF not, right click once on a clear spot on your desktop). From the pop-up window left click once on properties.
Display Properties will open. Click on the Desktop tab. Than click on the Customize Desktop button. Desktop Items will open. Make sure there is a check mark in the box next to, My Computer. That will add the My Computer icon to your desktop.
Right click on it once & from the pop-up window slide to & left click on properties. Click on system restore tab.
Reason for this: if your system has a virus or Trojan it will copy its self into system restore. Turning it off prevents this. 2.) Run your antivirus software & check for issues. 3.) Download the free software named ccleaner; http://www.filehippo.com/download_ccleaner/ & install it. Run the standard cleaner. Than click on the registry icon and scan for issues. This will remove double registry keys & corrupt keys. Than restart your system. When windows finishes loading click on update windows from the start button. Check for hardware & software updates & install em'. (If any). When you feel everything is running correctly you can re-enable windows system restore & create a restore point.
If everything above did not fix your problem you may have no choice but to repair windows. Load your windows restore CD into your CD-ROM drive and boot to it. Running Dell's restore should repair windows. Most of your data should be fine. Some programs may need to be reinstalled.
Cheers'
Mike
Jul 18, 2010 | Computers & Internet
I have broken.openco after scanning with malware bytes. i have scanned several times with this but keeps comming back how can i get rid of this?
Try to download and install AVAST antivirus Home Edition. It is free. Besides, avast has an option to scan at boot time so it can detect and delete viruses and malwares before they can cling to your system memory. You can download it here.
Jun 06, 2010 | Computers & Internet
Try to load software for microsoft lifecam vx3000 tells me not enough disc space or unexpected problem occured whats going on.
you have low disk space on your C drive
do a disk cleanup
steps
1:Starting Disk Cleanup Disk Cleanup is available on both Home and Professional versions of XP. The utility can be accessed in any of the methods listed below.
  • Click Start | Programs | Accessories | System Tools | Disk Cleanup
  • In Windows Explorer or My Computer, right-click the disk in which you want to free up space, click Properties, click the General tab, and then click Disk Cleanup.
delete unwanted files from My documents ,music folder,recycle bin ,-----------------------------
turn off system restore option
Steps to turn off System Restore loadTOCNode(3, 'moreinformation');
  4. Click OK.
you will get at 20% free space after doing these steps
then start the installation again
Mar 30, 2010 | Microsoft LifeCam VX-3000 Web Camera
I have a TSSTcorp cd dvdw ts-l633a combi drive fitted as standard to my brand new laptop but nothing appears on 'my computer' and device manager shows yellow ex mark against CDROM. Any ideas?
Follow these steps to resolve your cd dvd issue. It’s mostly caused by an error in the registry.
Next Step:
* SYSTEM
* CurrentControlSet
* Control
* Class
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
7) Reboot
your computer
That's it, guys!!
Till next time, take care of your laptop.
Idris Chambas
Sep 30, 2009 | Toshiba Satellite Pro L300 Notebook
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
