What drivers, give the Dell Optiplex GX150 better monitor resolution display from 16 bit, to 32 bit display?
  • manga_03jada Apr 24, 2010
    Yeah. I'm gonna do that. Thanks alot.
  • 355 Answers
It all depends on which video card you have installed, that model optiplex shipped with at least two different video cards. It would be best to go to the dell website HERE and put in your service tag number. It's located on the back of the PC on a white label with a bar code with a mix of letters and numbers. After you put in your service tag number it will give you a list of drivers specific to your PC. download the most recent driver under the "video" section and install it and see if that helps. your video card may no even be able to achieve 32bit color. as a last resort you can purchase a PCI video card and use it instead of the video built into the motherboard. pretty much anything you buy today will be able to achieve 32bit color
Posted on Apr 24, 2010
Dell optiplex
Yes it can, if otherwise all you will need to do is to reduce / high the screen resolution for better image and display.
by right clicking on your Desktop , scroll down to properties (if window xp), screen resolution (if window vista or window 7) and click on slider to increase or reduce the resolution . then you are done.
N:B: if the montior of the higher resolution would not display, make use of a normal one that will work to set it first and later return your new 24inch monitor. IT WILL DISPLAY BETTER.
Feb 27, 2014 | Computers & Internet
Need to change input signal to 1440x900@60hz
go to control panel and then display settings and adjust the resolution and refresh rate that way. if you don't have the option and your video drivers are up to date then your video card doesn't support a resolution that high.
May 10, 2012 | Dell OptiPlex GX150 PC Desktop
Dell OptiPlex GX150 no display no sound with yellow led
Hi, just pull out your memory card and clean it with an eraser. And insert it tightly again and don't forget to clean also the memory bank.
Hope it will help you.
Mar 27, 2012 | Dell OptiPlex GX150 SF PC Desktop
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
I have an Acer Aspire one and it won't let me change my resolution off of 800x600 I have windows 7 ultimate x64 (32-bit right?) i need help to get my 1024x600 res back.
Generally - you simply need to right-click anywhere on the desktop that does not have an icon present, and select "Screen resolution". Adjust the slider as needed to obtain the desired resolution. If the resolution desired is not available, choose another that is close.
Digging deeper, you might want to investigate the "Advanced settings" to make sure that you've got the correct drivers loaded in the settings for both the "Adapter" and "Monitor" tabs.
Lastly, "Windows Ultimate x64" is the 64 bit version of Windows. The 32-bit version is referred to as "Windows Ultimate x86" If there are both 32-bit and 64-bit drivers available for your Aspire, make sure you get the correct version 32-bit = x86 and 64-bit = x64. The "x86" tag came from the Intel processor line up where the "x" represented the generation (8, 16 and 32 bit CPUs) and the "86" were the last two digits to indicate the instruction set used by the CPU like this:
8086, 80286, 80386, 80486, etc.
The 64 bit CPUs are not x86 family processors, so they do not carry the x86 tag. Please rate this reply if it was helpful to you - good luck!
Jul 02, 2010 | Dell OptiPlex GX260 PC Desktop
Dell GX260 has distorted video on Dell 19" widescreen. Circles turn into ovals.
Most likely the Display Resolution is not set to a 16:9 display aspect ratio (1366 x 768 for example) if you use a 4:3 ratio on a widescreen, then everything is distorted. Make sure the display is set to the optimal resolution You can look up you monitor's Optimal Resolution here:
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~subcat=54&~cat=3
Jun 16, 2010 | Dell OptiPlex GX260 PC Desktop
Why does my monitor display go from 32 bit to 8 bit after bootup?
This has something to do with the software for yur video card , so the first thing to do here is to uninstall and reinstall the video card software to correct the problem.....
Aug 07, 2009 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
