Question about Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Automatic pump I understand the concept. What is wierd is the place to hook up the waterhose is up high and on the outside of the Shopvac itself. Is there another spot to actually hook up the hose inside the shopvac? I can't locate my manual. I do see a hole in the bottom of the filter but there is not an actual place to screw something in there? Im I just being stupid?
    President:
  • 1,314 Answers
Well that does sound strange but in theory if you hook up the water hose even up high when the water fills the reservoir it should run out while your vacuuming give it a shot and when you wet vac you have to take the filter out whats the brand well see if we can find you a manuel and are you saying the place where you hook the hose doesnt have a hole to the inside most ive seen are on the bottom
Posted on Mar 23, 2008
SOURCE:
Mod.#J150A shopvac won't turn on
These units are not high quality. There are problems with the motors and the switches, you can check these things or just get another one. If you get another one, get a different brand.
Feb 09, 2014 | Vacuums
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
The automatic drain hose is hooked up to the back of the unit, but when the bucket is full, the automatic pump does not work. The automatic pump should come on and empty the bucket, but it does not come...
Any automatic pumps operate off a swith that is turned on when the water rises. They normally have some type of ball lift, that will raise the switch when water is high and then drops with the water and shuts the pumps off. It sounds like yours is stuck and not activating the pump.
Jul 06, 2011 | Vacuums
Do you need a special filter for wet application
Yes. The following site shows the filters and which is used for what. Due to potential motor damage, I wouldn't use it without the proper filter.
http://www.shopvac.com/shopvac-accessories/Departments/Wet-Pickup.aspx
Jan 03, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I just bought a Hoover Power Drive Concept Two Electronic vacuum from the thrift shop. It only needed two belts and seems powerful. But i don't understand what the small red button on the handle marked...
The U6311-903 is a self propelled vacuum. The the small red button will stop the handle from moving back and forth, which makes the machine go foward and backwards. The red button disengages the self propelled feature.
Feb 06, 2010 | Hoover U6311-930 Power Drive Bagged...
ShopVac pump
hey thats great whatever works its what makes america great
Mar 24, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac 584-06-00 Canister Wet/Dry Vacuum Logo
357 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
