Question about Symbol LS 4071 Handheld
The Scanner is set up, paired and Connected through the usb cord it comes with so when I scan a Bar code it beeps but it DOES NOT place the numbers on the Computer Screen..
  • 1 more comment
  • froilan21 Apr 24, 2010
    I don't have the Driver CD, Where Can I download the Driver for it?
    I have looked for it and Did not find the Scanner in the Device Manager either..
    Where Exactly would I have to look for it in this list the Computer Gives me of Devices..
    The Model # is Symbol wireless barcode scanner LS 4071 LS4071 USB
    I bought t on Ebay and it came without a Driver CD..
    Thanks.
    the OS is
  • 4,924 Answers
Try to reinstall it if you have a driver for it ...it beeps cause it makes the scan ..being powered via Usb ...but it do not transmit the data cause it do not communicate to the computer ...
Try to take a look into the device manager to see if you find it by name and installed(if it is in yellow it means that is not installed)
in this case ..insert the disk that came with it .. choose the operation system you use and install the driver ...restart and try again to see if it works..
to verify it ...you get to the device manager by right clik on computer ../properties hardware...device manager
Posted on Apr 24, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Apr 24, 2010
    I see that you kinda hurry up ...I need to know the name and model for to get a driver ...and also your operation system ..
    another thing ..did you looked into the device manager to see if it is present and if ..needs a driver ?? take a look, if you find it in yellow ...right click and click update driver ...follow the wizard and see if windows have a driver for it ..(also you can try to change the usb port to see if windows detect it )and let install by itself ..meanwhile let me know the model to look for a driver or at least to see if it needs one ..cause some models work automatically ...
  • Catalin Turcu
    I didnt find any reference for a driver on this product ..so I guess is either automatically or it has it in the receiver ...so ...to look for it you should open the USB ports ..(the last in the list ) ..you should find it there ..at least as an unknown device ...clisk right and install and let windows see what to do ...my only concern (being a second hand) is not to have a problem itself ...cause this kinda devices are seen by the windows in the second you insert them ...and the wizard should scan for a DRIVER ..another thing that you should try ..is to run the add new hardware wizard from the control panel ..and let it scan for devices... a restart to the computer should also find the hardware ...automatically
  • Catalin Turcu
    being a uSB device you should look (open) the universal serial buses
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit &lt;Enter&gt;? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
NOT SCANNING CORRECTLY
I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
Dec 15, 2007 | Symbol LS2208 Handheld
Symbol LS 4071 Handheld Logo
108 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
