Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
I had 3 red blinks in my KDF-60XBR950 Sony Wega.How do I jumper the door switch? What do I need to put to hold the switch?
    Guru:
  • 416 Answers
The door switch is for safety. Is the door deformed (PN: X-4042-246-4), which is causing the error? Twisting the 2 wires together (after stripping) is a quick way to by pass the switch. If that fixes the problem, you should replace the switch (PN: 1-570-245-11). I hope this was helpful, best wishes.
Posted on Apr 24, 2010
The power button is blinking red what do i do
Probably a bad lamp. Pull your lamp door and check the bulb. Usually obvious if it's bad (ie. shattered, blown tube) replace and enjoy!
Mar 08, 2013 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with KDF-70XBR950 TV. The TV won't come on. The power light blinks green for a few seconds than it blinks red for a while until it turns solid red.
How many time it blinks will tell you what the error is. This site will provide you with the service manual and on page eight of it will give you the list of blinks vs problems.
http://www.givemefile.net/smanuals/lcd_tvs/sony/file/8935.html ) ( The middle of the page is the download link "Download SONY service manual KDF-60XBR950 KDF-70XBR950 repair manual" )
May 05, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
I changed the lamp but the lamp light keeps blinking and the tv won't turn on.
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
OR
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
May 18, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand Wega KDF-50E2000 3 red blinks
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a Sony Wega 42'' tv and it blinks green 50x.
If you move or hit or tap tv and you see more blinking that meens has cracked solder .need refresh board solderingin side tv
Apr 28, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-60XBR950
Zenit, When did you start having that problem? havent it turned on once? Do you still have the warranty?
Dec 28, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-60XBR950 Start up failure - Blinking Red Lights
anytime you put pressure on something to get it to work is not a fuse but a bad connection. in this case sounds like the door triggers a switch....maybe you can just bypass the switch. or you need a new door housing assembly. good luck
Aug 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
479 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
