Question about ViewSonic N3751W 37 in. LCD Television
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
  • jaywang66 Apr 24, 2010
    Thank you very much, Cindy. I did two things: select Air instead of cable in Tuner mode; change to default setting. Now I am able to get several air channels although I missed the recent Winter Olympic in Canada.
  • ViewSonic Master
  • 5,100 Answers
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Posted on Apr 24, 2010
Testimonial: "very helpful with some key info."
  • Cindy Wells Apr 24, 2010
    I'm glad that I could help.
My viewsonic N3751w 37 in, tv will not power on
Is the status LED light on at all, if so what color is showing? if the LED doesn't even't light up, then the power supply is gone. Also, have you try using another power cable?
Dec 03, 2013 | ViewSonic N3751W 37 in. LCD Television
Viewsonic n3751w stuck on one chaannel,
Do a factory reset to this set. Just unplug it from AC mains wall socket, and re-plug it after 10 minutes or so. This must make the set to a hard reset.
Nov 05, 2012 | ViewSonic N3751W 37 in. LCD Television
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a Sony Bravia KDL-46V2000 LCD television. I was watching a digital program on channel. All of a sudden the screen frooze and I turn to another channel and the screen display no channel allocated. I...
I have the same problem, the only solution I found so far is to disconnect the TV from the mains supply - not very comfortable. The problem seems to happen more and more frequently.
Feb 08, 2011 | Sony KDL-46V2000 46 in. LCD Television
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
I cann;t receive several network channels on my Dynex 26: L150A11 LCD TV using only an antenna (no converter box). Does this TV have a built-in digital tuner? Do I need to use anything else to connect ?
all new tvs should have a built in digital tuner. Make sure that tv is set to receive antenna signal and not cable by going into the menu. Use autoprogram feature if you haven't done so already. it will lock onto whatever signal is strong enough for it to see. Also if you are using an indoor antenna it may not be able to get enough signal to the box. Indoor antennas are not the greatest especially if the station is far away.
Sep 11, 2010 | Televison & Video
Need schamatics for viewsonic n3751w
There is no service manual available for a Viewsonic. You must trouble shoot it from knowledge. If you need assistance after voltage checks then feel free to re-post.
Apr 22, 2010 | ViewSonic N3751W 37 in. LCD Television
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
Picture too large for 37" ViewSonic screen
Try pressing the auto button.
If you can't find one try the + button or
right arrow button, then each other button in turn, one should reset to automatic settings.
If the onscreen display (OSD) comes up see if you can find an auto option by pressing the + or right arrow key
Jan 30, 2009 | ViewSonic N3751W 37 in. LCD Television
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N3751W 37 in. LCD Television Logo
617 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
