Question about Akai PT4298HD Rear Projection Television
Tv won't turn on.
I push the power button and the light for timer shows but, no turn on and then the timer light goes out I also lost my remote control. where can I get a replacement?
    Problem Solver:
  • 4 Answers
It sounds like a porwer board if you are good on working with tv's you and most likely get one on ebay and fix it for about 60$ allso the remote should be on there.
Posted on Apr 24, 2010
Testimonial: "The info was timely , indeed."
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept book..here it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Tv won't turn on only a red timer light appears when the power is pushed on
First press on the power button on the tv remote control. if it is also not solved then i think your tv has a internal hardware problem which may be failure of some electronic components. It will be better to take it to nearest service center
Oct 16, 2011 | Televison & Video
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I lost my code sheet. how do i get a new one.
Try to do this:
Guide to Programming the Remote
Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
Using Code Search:
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
SOURCE
Sep 29, 2010 | Innovage Jumbo Remote Control
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Lost codes
Try this turn on your tv manually,Then on the control remote push and hold the code search button until the indicator light stays lit,release the code search button now push and release the device button TV and next you gotta push and release the power button until the TV turns off ( you might do this per about 150 times be patience) when the tv turns off you push and release the Enter button and the code be saved.
Good luck.
May 10, 2008 | RCA Universal Remote Control
Akai PT4298HD Rear Projection Television Logo
386 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
