Question about Cameras
Fuji finepix F40fd The camera will turn on but the led screen does not. Pleas help. Thanks
  • Gavaqua Mar 23, 2008
    Hi
    I have tried the display button, I get the noise but no image comes up on the screen.
    The camera only takes a lithium ion battery, but no AA batteries.
    I cannot see the back of the screen so I cannot see the setup menu, is there any other way I can reset the camera?
    Thanks
  • 790 Answers
Hello Gavaqua ,
Hit the display button and give a try!!
Posted on Mar 23, 2008
  • Kanth raj
    Kanth raj Mar 23, 2008
    Or else make sure the batteries are fully charged. Also, make sure you
    are using the right type of battery...because ordinary batteries are
    just no good (this includes alkaline, super heavy duty, max etc). They
    don't have enough power in them to run a digital camera for long (the
    LCD uses most of that battery power).
    For cost effectiveness and a very good power source, you should be
    using rechargeable AA NiMH batteries (high capacity 2500-2700mAh). Or
    you can use non rechargeable Lithium batteries (such as Energizer e2).
    If you are sure that you are using the correct batteries and they are
    fully charged, and you still have a problem...then you could try
    resetting the camera to it's default settings (it's in the Setup Menu).
  • Kanth raj
    Try leaving the battery out for 10 minutes. Try also removing the
    external memory. Turn on and off the camera with and without the
    external memory.
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Damaged lcd screen on fuji F47fd
Buy a faulty donor camera off ebay with a good screen. F40fd and F45fd use same screen so gives you more chance of finding one quickly and cheaper (if you get one at a good price) than buying just the screen.
Apr 27, 2009 | Fuji FinePix F47fd Digital Camera
Photos saving to camera internal memory not to memory card.
go into memory on menu and choose change memory settings from internal to card
Mar 16, 2009 | Fuji FinePix F40fd Digital Camera
Hi my lens is stuck in the out position and zoom error is on the screen can you help finepix f40fd
Lens needs to be removed, carefully stripped and re-assembled. If the three small plastic guide luggs on the inside slide ring are broken sell for spares. Very hard to repair.
Dec 01, 2008 | Fuji FinePix F40fd Digital Camera
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
