Question about RCA D61W20 61" Rear Projection Television
Power problems, not turning on, only when it wants too
    Problem Solver:
  • 4 Answers
You can replace the power board it should get it going
Posted on Apr 24, 2010
My canon MF4412 is power on but display is coming turn the main power on E202-0002
my mf4412 printer displaying a problem e202-0002 and red button continue burning
Jun 24, 2012 | Canon Office Equipment & Supplies
When i turn the computer on the power button turns yellow but it don't turn green
1.Blinking or solid amber - "Power Problems"
2. If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
3. Ensure that the microprocessor power cable is securely connected to the
system board.
4.If the problem persists, contact Dell.
Dec 28, 2010 | Dell Computers & Internet
Upon initially turning on power the tv lost sound and went black and would not turn on again.
The television is having a power problem, that is why it is no turning on, it most likely is as a result of a bad capacitor on the power panel of the television.
Have the power panel replaced the assess the main panel for any problems.
Take care and good luck.
Also check the sound ic, it might hsve been burnt due to some bad power problem.
Oct 25, 2010 | Sharp 27C-240 27" TV
Hp proliant ml150 g5 suddenly turned off by itself and refuses to start again the power it's powered very good and the power supply is working and the mother board looks powered but when I press power...
I had the same problem. The problem is the power button, it's not in short circuit, but I measure the
resistance when it is open, and it seemed to be a problem of it cable's isolation. We replaced the power
button's cables and now it's working.
You can replace the switch and the cables to assure the problem is fixed.
Good luck!, Esteban.
Sep 11, 2010 | HP ProLiant ML150 G5 Server
MY COMPUTER IS NOT COMING UP
when you say not coming up meaning not turning on?
>If its not turning on and no lights even on power button but monitor is powered up try swapping power cable of monitor to your tower to check if its just power cable issue
> if still not turning on and no lights at all then you have problem on power supply
> please advise me if the computer gets light because youre problem might be caused by a different thing if the system is turning on but its not booting to windows so please provide complete details of the problem
Jun 05, 2010 | Intel Desktop Board D845GLVA...
Does not turn on
have you checked the power pack connection if it is well connected to the mother board?
Also, does the fan on the power pack work when you turn on the mother board.
Since its not turning on, then the problem is a power related is problem. Therefore, you need to check those areas that supply power into the motherboard, such as the; power cable/cord, power pack, etc.
I wish you good luck.
Mar 22, 2010 | Computers & Internet
Xbox 360 won't turn on
To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Sep 01, 2009 | Microsoft Xbox 360 Console
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
Problem turning power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Problem is in mother board. Shot in capacitor has shown in image. Replace it....3cfd270.jpg
Jul 10, 2008 | Dell Inspiron 600M Notebook
PIONEER DEH-P7500MP
Ok so I just fixed my problem. Although I was getting the error because of using an iPhone instead of a CD I believe it is the same solution.
As jjgomex suggested it was pulling to much power, to what I did was turn on the headunit switch the source to something other than what causes the problem.
Then go to the Audio settings in the menu and turn bass all the way down and Sub Control to -1.
Then turn off headunit and turn it on again and switch to the source of problem, it should be fixed, or at least it did for me.
:) Good Luck!
Nov 14, 2007 | Pioneer DEH-P7500MP CD Player
RCA D61W20 61" Rear Projection Television Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
