Question about Dishwashers
No watter spraying in side and makeing more noise then normal.
  • 523 Answers
Change water valve
Posted on Apr 24, 2010
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
My 1995 saturn i wrecked it then i fixed watter pump no leaks except for overflow of coolant which i use watter right now lol but its after i put in the fuses tha it started running at 2300 rpm how do i...
Take a spray bottle and start spraying around the hoses on the motor, with engine running. When the engine slows down in any area, look for a broken hose and repair it. That should bring the rpm down.
Jul 30, 2013 | Saturn SL1 Cars & Trucks
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
Creaking/friction when I hit a bump?
Still sounding like a bushing, but it also could be related to a strut. I have tried this in the past....jack the car up and ONLY on one side first, use WD-40 and spray each of the bushings well. Leave the upper strut area alone...do your normal driving. If you still have the squek/crunch, etc, spray the upper strut area. A rare ocassion it can be the upper strut mount.
let me know how it goes!
Oct 27, 2009 | 1990 Acura Integra Hatchback
Ice maker is making a creeking noise.
Right after a batch of ice is released into the bin spray the ice making forms with some PAM or other no stick food spray.
May 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Noise from area of serpentine belt.
The best way I have found to locate a belt noise is to take a can of WD40 and spray it on the belt when the engine is running. (be careful of the fan) If the noise goes away, you know that it is a belt noise and not a bearing. When serpentine belts dry out they make funny noises. Hope this helps, cheers
Apr 08, 2009 | 1993 Volkswagen Passat
Noise when spraying
The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
Feb 05, 2009 | GE 24 in. GSD2030Z Built-in Dishwasher
SHUTING DOWN DURING WATTER DRAIN
defective pump..but replace pump and belt at the same time,,,onthejob
Jan 09, 2009 | Maytag Performa PAV2200
2002 explorer makes a wining noise when you shut it off
This could the problem with belt , get the belt tightened.....
Good luck...
Nov 20, 2008 | 2002 Ford Explorer
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
