Receiving fax has vertical lines on paper. - Office Equipment & Supplies
  • Office Equip... Master
  • 6,161 Answers
Are the fax from the different fax numbers or the same if the same may be there fax machine have them clean there scanner, if from varioue fax numbers then check your toner/drum unit and print out some internal reports such toner/drom order repkacement orders or one touch numers or meter read forms or make a copy if able to copy with this machine is line gone? Also check your fuser unit the hot part. also check your scan glass
Posted on Apr 25, 2010
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
Faxes received have thick vertical dark lines
Make a copy of something to tell if you have a bad toner cartridge
Feb 04, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Vertical lines on copies received
Run a copy of something through your machine. IF the lines show up on your copy, and also lines on your incoming faxes, then your drum cartridge is bad.
Replace the drum cartridge with a new one and you should be back in business.
If you have any other questions, please post again.
I hope I have helped you with your question.
Please remember to post a rating if I have helped you.
Have a good day.
Mac =)
Jun 04, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Trouble shooting
Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
Nov 12, 2007 | Office Equipment & Supplies
138 people viewed this question
jasbo
jasbo
