Question about Jetway V266B Motherboard
Connecting audio to front of computor box from motherboard
Computer box has a cable with seven pins to conect to audio on back of motherboard spk r+l in r+l mic-in mic-vcc and gnd The audio connection is nine pin configoration.I have lost the motherboard manual i am not shaw how the seven go on the nine
reguards almac
    President:
  • 2,351 Answers
Elecstar, do your self a favior & download this manual asap.
It will not be listed for much longer. Click the link below than click Manual.
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
connecting audio to front of computor box from mot - 430fcb8.jpg Have more questions, feel free to ask.
Good Luck!
Mike
Posted on Mar 24, 2008
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Info to connect front panel leds
Each of the ends of the cables that lead to the LEDs should be labelled, e.g., 'PWR/power', 'RST/reset', 'SPK/speaker', 'HDLED/hard-drive-LED', 'PWRLED/power-LED'.
Connect each labelled connector to the labelled pins on the motherboard.
May 29, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
How can i connect my frontal audio
Connect the cables from the front audio ports that comes from your computer box to the pins on your motherboard. The cables have markings on it eg. left, right and ground (can't remember exactly) which you have to connect to the corresponding pins on your motherboard. You will have to look in your motherboard manual for info on the pins.
Sep 25, 2009 | ASUS S478 VIA P4V533-MX Motherboard
Where does the spk/mic wire go ?
You can download the manual for your board from Intel here. It will show you the location and pinout of the front panel audio header.
May 17, 2009 | Intel Computers & Internet
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
Front audio connections
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Dec 15, 2007 | A-Top XBlade Mid-Tower Case
Frontpanel sound
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
Nov 18, 2007 | EliteGroup P4M800-M7 Motherboard
Jetway V266B Motherboard Logo
438 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
