Question about IBM Infoprint 1532 Laser Printer
241.10 paper jam, check tray 1 keeps coming up, I checked over & over and there is no paper jam. I restarted computer, I plugged & unpluged, I etc.... PLEASE HELP!! I am working on a deadline I have to complete!
SOURCE: lexmark c510 241 paper jam error
had same trouble with card stock
I read the manual...lo! There are markers on the inside of the feed tray for various media. Complied with these markers, and no more problem. Should work for paper too.
jre
Posted on Feb 27, 2008
Cops
  • 64 Answers
SOURCE: when i try to print anything, i get a message 241 paper jam,
this is most likely to be worn pick up rollers. these are the two rubber wheels that you can see underneath the printer when you remove the tray. you should be able to source these from a local suplier and are very easy to fit. just make sure your gentle with the clip that holds them in place as if they break then you will need to buy a whole new pick up assembaly which is significantly more expensive.
hope this helps
Pete
Posted on Nov 25, 2008
SOURCE: back cover open error message MFC 7820N
Reseat inner rear paper guide to allow sensor to home correctly
Posted on Mar 09, 2009
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
sys_admin
  • 829 Answers
SOURCE: Getting the message
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Posted on Jan 26, 2010
Fake paper jam Laser jet M176n
have you unplugged it and turned off the computer and restarted if essentially you have it hooked to it?
Mar 07, 2016 | Laser Office Equipment & Supplies
My printer cartridge has gone beserk
Follow the instructions below to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Turn on the printer (still disconnected from the computer) and check the lights / lcd screenmag-glass_10x10.gif.
4) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
5) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
6) Try to feed paper manually (using the paper feed button).
7) Before re-connecting the printer to the computer, uninstall the printer driver and restart the computer.
8) Re-install the printer driver.
Oct 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp offficejet 5610 printer showing paper jam
Try This :
>Open the rear access door clean the rollers inside it with the help of a Lint free cloth moistened with some distilled water.
>Check inside the printer if there is any paper jammed inside.
>Unplug the power cable from the back of the computer
> Keep on tapping the power button of the printer
> Plug in back the power button.
> Try to do a photocopy and see if it works .
> Again unplug the power cable from the back of the printer . Press and hold down the (#) & (9) and then plug in back the power cable . Then release the (#) & (9) button.
> It will perform a reset . If still it doesn't work check the link given below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=ca&lc=en&dlc=en&product=441125
Still if it doesn't works can contact HP for repair or Replacement
Hp No.: 1-800-474-6836
Regards
Shrey
Oct 07, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer jams even with no paper in it
try to check visualize inside the printer maybe there's a thing that cause the jam.and try also to
restart your printer and your computer..and add some paper to the tray in order to paper pick mechanism to pick them easily unplug it and plug it again..
Good luck..^_^
May 18, 2009 | HP PhotoSmart C4385 All-in-One Printer
Photo tray output problem
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Jul 29, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper Jam Error on HP 2015
For whatever reason the printer internal programming became corrupt showing that there is a paper jam. After checking the paper path and a quick can of air sprayed into the tracks, I proceeded to attempt a Cold Reset.
1) Remove the paper tray.
2) Remove toner cartridge.
3) Unplug USB.
3) While plugged in to power, turn off the printer, hold down the 'GO' button and power it back on. Continue to hold for more than 5 seconds but less than 15.
4) Reinstall the tray (be sure to check the paper level indicator is operating when you add paper to the tray. The lever should move up as it fills with paper)
Reconnect the USB cable (make sure you are using a thick USB cable and not a cheap thin one, very important. Make sure the printer is not plugged into a backup batter either) Never plug a printer into backup power.
I noticed that the computer did not recognize the device when connected which prompted me to contact HP support.
HP Support is shipping out Item # CE517AB - Font/DIMM Program for me to install in the printer to most likely reinstall the firmware.
I will post back if this works to flash the firmware or just waste some time.
Jun 23, 2008 | HP LaserJet P2015 Printer
IBM Infoprint 1532 Laser Printer Logo
555 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
