Question about LG DLG0452W Gas Dryer
LG gas dryer DLG0452W drum makes a clicking noise
LG gas dryer DLG0452W makes a fairly loud clicking noise when the drum turns, even when empty, as if something is attached to the outside of the drum. I can hear the click go from the left side of the dryer to the right and back again, as the drum spins.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 200 Answers
One of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Posted on Apr 25, 2010
My gas dryer LG 452 makes loud noise thumping when first starting then will cease after a few minutes. Was all quite before installing recall gas valve. now very noisy when first turned on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 27, 2011 | LG DLG0452W Gas Dryer
My LG gas dryer makes a noise that sounds like when you put shoes in it, but the drum is empty. How does it come a part so I can see why the drm is making such a loud noise?
heatman101
Jul 17, 2011 | LG DLG7188 Gas Dryer
I have a LG (DLG0452W) gas dryer. It will tumble, but no heat. The light bars by the timer display are flashing orange instead of green. What could be the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | LG DLG0452W Gas Dryer
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Jan 10, 2011 | LG DLG0452W Gas Dryer
How do I get the back of a LG Dryer DLG0452W off?
You cannot get the back off. You work from the front.
Remove the top first by getting the rear screws off then remove the controls and top front brace then remove the drum glide then the take the belt loose and lift out the drum. You will now be able to examine the motor.
May 03, 2010 | LG DLG0452W Gas Dryer
Lg dlg0452w no heat, gas comes on for first 30
Sounds like the coils on the gas valve itself done by the igniter. When they get weak they can only hold the gas valve open for a short time. If you leave it long enough does the igniter come on but the gas not light? That is a sure sign the coils are weak. Sometimes they will even make a clicking sound as they try to open. They are pretty cheap and nearly all dryers use the same coils. They are little black cylinders mounted on top of the valve. Let me know that doesn't make sense.
Apr 29, 2010 | Dryers
LG Gas Dryer (dlg0452w) needs a push to get going
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 19, 2010 | LG DLG0452W Gas Dryer
LG dryer DLG0452W not getting hot. (gas not turning on)
reset circuit breaker outside burner chamber, and cleaned out the unit.
Feb 24, 2010 | LG DLG0452W Gas Dryer
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
LG DLG0452W Gas Dryer Logo
361 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
