Question about Dryers
DRYER KEEPS TRIPING CCT BREAKER
    Champion:
  • 210 Answers
Unplug. Ohm out plug between nuetral and hot legs to see if
a direct short. If not probably bad motor.
Posted on Mar 23, 2008
Tcl 770 keeps triping power
Check to make sure the breaker is rated for the current draw of the dryer. If it is, you MAY have a bad breaker. Replace your breaker and If the dryer is still tripping the breaker, your dryer needs to be repaired by a qualified technician.... the heating element is probably burned up and shorting out.
Mar 02, 2014 | Hotpoint Dryers
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Breaker keeps triping
Did it work trouble-free before?! Is it on its own circuit?! Are you sure breaker is of appropriate rating?!
Jul 09, 2012 | Refrigerators
The dryer keeps triping the breaker when pluged in and not runing
You need to check your power cord. Here is a video to walk you thru it.
Nov 26, 2010 | Kenmore 72062 Gas Dryer
My condenser dryer keeps triping electricity
You have a short circuit on the machine and the breaker is trying to save your life.
It could be the elements have gone down or a wire has rubbed through or even a switch has melted
It requires a person with a test meter and some knowledge of the machine to open it up and take a look
Sep 21, 2009 | Hotpoint Dryers
When i turn on the dryer it keeps triping out the electric. what could the problem be?
1) Short in the dryer heater element.
2) Breaker / fuse is not high enough amperage for dryer.
3) Too much running on the same circuit as the dryer.
Sep 15, 2009 | Dryers
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
My tv cant turn on
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
May 26, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Clothes Dryer not working
if it is tripping the breaker right away there is an issue with the drier shorting to ground. unplug and look for a broken wire in the drier. if the drier runs for 10-15 min maybe 30 before it trips the breaker. there is a loose connection in the wiring. either at the junction box in the wall behind the dryer or at the breaker panel. If it is in the electrical I would call an electritian. Good Luck!
Sep 24, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
