Question about Gateway FPD2185W 21 in. LCD Television
I am trying to run pip with x box in the pip and regular comp on main screen but it dosent work the xbox is hi def cables
  • Gateway Master
  • 5,166 Answers
What inputs are you actually using? If you use VGA as the main display, the PIP feature will work with DVI, 480i (SD) Component Video, S-Video, or Composite video. If you use DVI for the computer's input to the TV, the Component video PIP doesn't have the 480i limit.
Thus if you have VGA from the computer, Hi-def from the X-box isn't going to work. Note: The component video can not be the main screen with VGA input in PIP.
I hope this helps.
Posted on Apr 24, 2010
Tv show pip but not regular screen.
It sounds like a problem with the tuner in the set.
Every set with PIP has either a dual tuner or one for PIP and another called Main.
To prove what your problem is hook the set up from the cable box to one of the video inputs and see if it works that way; also if a DVD or blue ray work via the rear inputs it is a tuner problem.
If set actually has 2 tuners (one for PIP and the other for main} it can be either tuner causing the problem as they are interconnected.
Confirm no problem when av inputs are used.
Even if you do not use a cable or satellite box now, that way would cost you little compared to having a tuner replaced.
Let me know if you have questions with a comment posted here, the site will email me, it is not fast but let me know if you have questions.
SD TECH
Jan 15, 2011 | Akai PT5492S 54" Rear Projection...
When i turn my xbox 360 on it will play the sounds but no video
If your using the hi-def cable(red blue green) check that its switched to either standard of hi-def. Also if your using the hi-def cable it wont work if u have the white head in the same time as red blue green! Hope it works for you!
Mar 14, 2010 | Microsoft Xbox 360 Console
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
Display delay
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Aug 17, 2008 | LG 42LC2D 42 in. LCD HDTV
NON- Hi Def channels loose thier blue? color....picture is all green
Some CATV hi-def receivers are known to have issues keeping up with the datastream. Symptoms from the picture going solid black to other unpredictable video have been seen. Ask your CATV provider if they can switch your brand to another manufacturer. If your cable box has component video jacks in addition to HDMI, try that too. Some boxes will output RGB perfectly but bomb out with HDMI.
May 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
HDTV Problem
there shouldnt be a problem with the cable, if you use the component leads then you will not need to use the s video cable for video incase that is what you are doing, component only uses 5 connectors and the switch should be set at HDTV not tv and the tv set at component Use the following colours into your tv:- Green, Blue, Red and the audio red and white, you do not need the yellow or the s video plugs. Then select the 1080i when in the component setings on your tv and do the same in the dashboard settings
Jul 01, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
140 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
