Question about Samsung HP-R5072 50 in. Plasma HDTV
Where can i find a ceramic fuse for my samsung Plasma TV model # FPT 5084X
If you have any luck finding one let me know. I rode around town for most of the day going from commercial electronics stores to specialized electronic companies. No one seems to carry a 12 amp 250Volt ceramic fuse.....I tested mine it is definitely bad, just can't seem to locate a place that sales these fuses.
Posted on May 12, 2010
    President:
  • 1,768 Answers
You can probably find it at All Electronics or Digikey
do a Google search for the sites.
the best place is the source from which it came the Samsung CO
You can also go to a local TV repair shop and as the tech there to order it for you for a nominal fee.
Posted on Apr 24, 2010
  • 1,557 Answers
Any tv repair company will gladley sell you one ever the counter if you have the blown one take it with you if not ask them to check the right values
hope helps
My plasma samsung ppm63mf7: no power, all caps OK, ceramic fuses OK, I replace a failed sustainer board. Now power just clicks and blinking power light\r\nSo I unpluged T-con board and Main board to check...
I had a similar problem with mine, i had to change couple of caps but it still would not power on. I ordered one online and it seemed to solve the problem. the power supply board for the TV are a bit expensive but this guys over at had one for under 200 dollars, http://myoemparts.com/power-supply-boards/53-bn96-03736a-pspf771f01a-power-supply.html
Jun 22, 2011 | Samsung PPM63M7F 63 in. Plasma TV
NEED 12 AMP 250 VOLT CERAMIC FUSE OR PART# DH81-11975A
You can find that part Here
Happy to help
Positive Feedback ALWAYS Appreciated :)
Mar 07, 2011 | Samsung FPT5084 50 in. Plasma HDTV
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
40" plasma with blown fuse
this one has a few bad caps in the power supply,C5 and C6 330mf at 450volt and Q6,Q8 are problably bad part number K2372,you mite want to replace the power supply board part number BN96-00249A
Sep 24, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My Samsung FPT5084 just shut off this morning. Th
You will need to upgrade that fuse with a Samsung authorized upgrade. The part number is DH81-11975A and is available from
http://www.hermanelectronics.com/HermanStore/homepage.asp
If you use just the standard type it will go again in a few weeks.
Sep 12, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung FPT 5084X won't turn on
Sorry, but welcome to the world of highly efficient, component-critical switching power supplies.
These are all of those things and the failure often is related to a specific type of component, an electrolytic capacitor. These are chemical devices and cheap ones fail easily, the most expensive take little longer but the primary value shrinks while the losses climb until the part cannot do what it should any more.
The main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Aug 27, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Need to buy the stand for my fpt 5094 samsung
Go on amazon.com or ebay.com.Make sure ur tv work first ok.U can buy it use or bit on Ebay
for use tv parts.
Aug 13, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Tv shuts off wont come backon samsung fpt5084x
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Mar 06, 2009 | Samsung FPT5084 50 in. Plasma HDTV
No power to Samsung FP-T5084
Jan 22, 2009 | Samsung FPT5084 50 in. Plasma HDTV
My dead 42" plasma - power problem
I have same issue with Samsung HP-S4253 Plasma. The fuse is a Littlefuse (manufacturer they do not sell), I have search and called over 20 places and the latest is Fuses Unlimited but it is discontinued and they do not stock but they can order. I will not be able to contact them until the holidays are over. There most likley is a minimum order. If there are other fuses you need write down part #'s so you can fill the minimum if required.
If there is anyone out there that can help with finding these hard to find fuses it would be appreciated.
There are most likey other Plasmas or TVs that use the same fuse just have to figure out witch ones they are.
Fuses on Power Supply Board: The 8 amp is the one I require.
T8AH250V P
T10AH250V
Break Down of Fuse Description:
T = Time Lag
8A = 8 Amp
H = High Breaking Capacity (Ceramic) 1500A @ 250V AC
250V = 250 Volts
P = RoSH Compliant
Aug 25, 2008 | Toshiba 50HP95 50 in. Plasma Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
1,023 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
