Question about EliteGroup 760GX-M (760GXMWXP2800FAN) Motherboard
After changing the motherboard to a new case sound stoppedthe only thing that is different is the new case has a front usb/firewire/sound port that I had to plug into the motherboard. Im positive I plugged them into the correct spots but the sound went away. even after I unplugged the front usb stuff and made sure tings were exactlty the way the were before the sound still hasnt come bacl
    Sergeant:
  • 279 Answers
1. Go to device manager, see if there is no yellow question mark, and ensure the sound device type appears to ensure all drivers are installed.
2. Do you see any volume icon on the taskbar? And check the volume level.
3. Check the audio jumper
Posted on Apr 24, 2010
Mhy maxtor external hard drive is not being recognized by my computer. What do I need to do?
Does it work when connected to a different computer?
If not, is it still under warranty?
If not, disassemble the case, and you'll find an "internal" MAXTOR disk-drive inside the case; try connecting that drive as a "slave" disk-drive inside your computer. If it is not recognized, then it is "dead" and you should take a hammer to it, so that any of your personal data on it will become impossible for any "identity-thief" to read, and then buy a new, larger, external drive.
Sep 13, 2009 | Maxtor Hard Drive
Just need the pin out assignments for J11 USB header on Compaq 431F9P01K7C motherboard. I am trying to use the front USB ports from an old Compaq case, case to, with new motherboard and need to know if...
Most motherboards (99.8%) use the same pin assignments, they just tend to place the connection in different location per board. With usb connections, you should be more than capiable of making the connection, possibly the only issue is do you have enough lenght to make the connection within the case. Good luck and I hope this helps you out.
C2Solutions
Aug 10, 2009 | Computers & Internet
Damaged USB ports.
technically usb in case is wired in motherboard
Jul 10, 2009 | Cooler Master (CAC-T05-WWC)
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not...
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
May 30, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Usb & Front panel Problem..!
these front usb ports cause prob lem always kindly change the whole panel with usb ports in front they are faulty and giving problems and will create more problems if u dont change them kindly get new one u can find them easily on any store and simply chang them see the connector going to the motherboard plug it out and plu the new one at same location
rate me WELL !
Regards
May 23, 2009 | Gigabyte Computers & Internet
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
HP a220n (midtower PC) replacement
Duane , a good AMD 64 x2 Duel core processor motherboard would be the Asus M2A-VM AMD Socket AM2 MicroATX Motherboard / Audio / Video / DVI / PCI Express / Gigabit LAN / USB 2.0 / Serial ATA / RAID this motherboard will fit in your midtower. It comes with firewire and usb ports. hope this helps.
Sep 17, 2007 | HP Pavilion a1220n (A1220NED904AA) PC...
EliteGroup 760GX-M (760GXMWXP2800FAN) Motherboard Logo
47 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
