Question about Philips Magnavox 51MP392H Rear Projection Television
My tv looks like im in a fog what can i do to fix this? It appears to be heavy on the blue side also. 51MP392H/17
    Guru:
  • 416 Answers
You need to change the glycol in the Blue CRT. To be honest... this is one of the most miserable jobs you could ever want to do. You need to pull out the blue CRT, remove the drain plug, empty the glycol, disassemble the mechanical seal, clean the scale off the CRT and C lens, reassemble the mechanical seal, refill with glycol, install the drain plug, install the CRT in the TV and then, re-converge the TV. Sound fun?.. it's not. The first time I did one of these the glycol leaked all over the place and destroyed the TV. Also, glycol is just nasty... slops up your hands and your tools and your work area. If you tackle this, good luck to you. You can get the glycol from MCM Electronics. I hope this was insightful, best wishes.
Posted on Apr 24, 2010
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
51mp392h/17
You need to replace your STKs Big black ICs 392-020 replace both of them also check 2 resistors 2,7 ohms they may be open.this is a common repair iob.
I have a magnavox 51mp392h rear projection tv and im having problems with the convergance
51MP392H/17
Where I got my parts that worked:
What you need:
chips
Oct 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox MDL 51mp3964h distorted and waved picutre
Hello pkrocks
It looks like your convergence amplifiers have gone bad, this is a common problem. If your set uses the STK329-110 or STK329-xxx series of amplifier both of them will have to be replaced. There is a lot of information on fixya about how to do this yourself, but you have to be careful in removing and replacing the amplifiers and the associated bias resistors.
I hope this helps
Thank you,
Shuttle83
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp392H/17 convergetnt problems
When I turn on my magnavox 51mp392h/17 the sound and picture works but there is a sizzling sound coming from inside of the tv I looked and the sound is coming from what looks like a coil it has 4 lines coming from it 3 of which go to the color projectors and one to what looks like a transformer. Can you help me out?
Jun 06, 2008 | Televison & Video
Blue Color Convergence wont adjust
yes by all means . I will post a link where you can get your replacement ICs along with free installation instructions with pictures. They also provide free on-line instant messaging while your doing the repair which only takes about an hour from start to finish. I am one of the support techs. Your model uses STK392-110 or STK392-120 either IC interchanges with each other except the 120 is a better IC runs cooler.Heres the link.You will need to replace both ICs
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
51mp392h/17
HAVE RED BOW . BLUE IS GOOD . RED I CANT AJUST JOESTV2003@YAHOO.COM
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
