Question about Sony PlayStation Portable (PSP) Console
My games stored in my PSP HDD won't appear when I click in Games!
Everytime I turn on my PSP. Then I went into the games section, but after awhile, it opens, and nothing appears! It says: "There are no games...". But when I open it in my PC, the games are still there. Is there a solution to this?
  • Phi Vu
    Phi Vu Apr 24, 2010
    Yes. My memory stick. I forgot its name.
Are you talking about the games on your memory stick ? or the disk?
Posted on Apr 24, 2010
How do i download games from my pc to my psp?
downloading a game from a pc to a psp won't play on the psp in any case, unless you install custum firmware on the psp by buying a custom firmware kit of www.amazon.com. If you don't want to do this any easy way of downloading games for the psp is buy using the psp store on the psp, which you should be able to get if you have the latest update. You can download the games from the psp store but they are not free. some of them actually cost more than just buying a UMD disc from a game shop.
Sep 17, 2011 | Sony PlayStation Portable (PSP) Console
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
Everytime i go to a psp store,the store owner always say that my psp needs to be modified b4 they can download games into my psp. Does my psp really needs to be modified to play downloaded games?
Yes and No.
The only legal download games are in the Playstation Store.
If you are downloaded illegal versions of the PSP games, you need a modified PSP to play them.
If you are attempting to download ROMs to play on emulators, you also need a modified PSP to run the emulator.
Jun 20, 2011 | Sony PlayStation Portable (PSP) Console
How to get psp games
Try these steps : 1.
Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews; later versions have protections that avoid use of non-commercial PSP games.
To check your PSP's firmware, press the PSP's "Home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
Format a PSP memory stick. The size of the memory stick doesn't matter since most PSP homebrews are relatively small. Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
Press the "Home" button and go into the "Settings" section. Scroll down and select "Systems Settings." In the next screen, continue scrolling down until you can select "Format Memory Stick." The PSP will ask you if you want to format the memory stick. Answer "Yes," and the PSP will format the memory stick within just a few seconds.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding; links are provided at the end of this article.
4.
Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, for the PC, or Stuffit, for Macs. Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.
Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.
Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then selecting "USB Connection."
7.
Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by "right-clicking" in the PSP directory and then entering in the name "Game."
8.
Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
In case of any problem please revert back
May 22, 2011 | Sony PlayStation Portable (PSP) Console
How to get psp games in memory chip
How to Put Games on a PSP MemoryCard
Because of the PSP's lack of onboard storage, most games that are downloadedfrom the PlayStation network must be stored on memory cards. However, this isnot necessarily a bad thing, as storing games on memory cards allows you tokeep games on different cards and swap them out at your leisure.
1. Go to the PlayStationStore on the PSP by clicking on the link in your cross-media bar. You will needto log in using your PlayStation Network ID. If you do not have one, you canget one by clicking on the "Get a PlayStation ID" button in thestore. 2. Browse for games. You canbrowse the PlayStation store by genre, title or release date. If you arelooking for something specific, you can also use the search bar at the top ofthe page. 3. Purchase points to pay forgames. If you have a credit card, you can purchase points from the storedirectly. If you do not have a credit card, you will have to go to a GameStopor Best Buy to purchase a card. After you purchase the card, you can add pointsto your account by going to the "redeem code" section of the store. 3. Insert your memory card. After deciding which game(s)you want to purchase, make sure you insert the memory card you want to use intothe memory card port on the side of the device. 4. Download the game. Click on the name of the game, andthen click on the "buy" icon. After your PlayStation Network pointshave been subtracted from your account, the download will start automatically.Do not turn off or reset your PSP while the download is in progress. You willsee a notifier pop-up when it is finished. Read more: How to PutGames on a PSP Memory Card ' eHow.com
Nov 10, 2010 | Computers & Internet
Same problem: PSP games in HDD
This may be because your games are downloaded from the internet?
You have to put them in a special directory
Apr 24, 2010 | Sony PlayStation Portable (PSP) Console
Games are not working
you need to update the firmware of your psp to a third party software in order for you to play downloaded games.
Aug 25, 2008 | Sony PlayStation Portable (PSP) Console
Psp mem stick problem
Me too I had the same problem.. It is not your psp console that doesn`t work it is probably your game. If your game is on a memory stick it was probably missed copied to your memory stick. If not just bring bck your memory stick to the store where you purchased it and ask for an exchange for another one. Before doing this format your memory stick because copying games on memory sticks is completely ILLEGAL!!!!
Mar 08, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
