Question about GE Profile 21.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22PRBWW
How to remove the door on my ge tfx22v? - GE Profile 21.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22PRBWW
    Scholar:
  • 126 Answers
REMOVE THE HEX HEAD 5/16 SCREWS ON THE TOP HINGE UNDER THE COVER. THEN LIFT UP DOOR. ON THE FREEZER SIDE DO NOT FORGET TO DISCONNECT THE WATER LINE AT THE BOTTOM OF THAT DOOR.
Posted on Apr 24, 2010
How do you remove the door handle for a GE microwave oven, model number JVM1190BY001?
You have to remove the choke that is around the door. After you remove the choke you will be able to access the screws that hold the door handle on.
Mar 22, 2015 | GE Microwave Ovens
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
How to open ice/water dispenser on GE PSS26LSRDSS to replace ice door flap
TAKE SMALL SCREWDRIVER AND GENTLY PRY OFF DISPENSOR COVER, THEN UNPLUG 3 SETS OF WIRES FROM BOARD. THEN REMOVE 4 SCREWS HOLDING ON THE DOOR ACTIVATOR. DOOR RECESS THEN CAN BE REMOVED AND REPLACED.
EITHER UNPLUG UNIT OR OPEN FREEZER DOOR TO PREVENT ELECTRICAL SHOCK.IF OPENING DOOR KEEP DOOR OPEN WILL KILL POWER TO THE BOARD AREA.
Jan 17, 2013 | GE Refrigerators
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
How do i remove the door from a side by side ge fridge , the bottom spacer has broken in half and the door will not close without lifting it.
Don't need to remove door, just get new piece, then block door up remove hinge and replace, just be sure to keep door closed and lighten it up by removing food from it..
Jan 03, 2010 | GE Refrigerators
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
Trying to remove oven door
ge spectra elec., how to remove the oven door
Jan 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge profile gas range jgb908sel3ss
most doors lift right off their hinges when the door is opened about 6 inches. A few have screws on the inside which have to be removed before you pull the door off.
Mar 04, 2008 | GE Profile Spectra JGB920SECSS Gas Kitchen...
GE JE1540WW03 Microwave Oven
When you remove the door, it's absolutely critical to get it back on exactly as it was, or microwave leakage can result. I only recommend removal of the door in cases of several damage or when separate door parets are not available. Door parts should be available for this model. You can find an exploded view of this model by entering your full model number at the GE parts Web site at: http://www.geappliances.com/shop/prts/ The exploded view should give you some idea of how it comes apart and goes back together.
Nov 24, 2006 | GE JE1540 Microwave Oven
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
