Question about Kenmore 43142 Front Load Washer
What is code F-24 - Kenmore 43142 Front Load Washer
    Scholar:
  • 126 Answers
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Posted on Apr 24, 2010
The autorization code activation type : Normal 24:24 for cs2
Adobe Photoshop Cs2
Serial Number :
1045-0436-9551-0266-5984-9386
Activation number :
3211-5436-3124-2065-0085-7491-3994
Activation type : normal 24:24
What is this
Please send Authorization code my mail id
sriram.divakar81@gmail.com
Apr 15, 2013 | Adobe Photoshop CS2 for PC
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
Please give authorization code for adobe premiere pro 2.0 my serial number:1132 - 1285 - 5953 - 8545 - 6450 - 4790 my activation number:2453 - 4521 - 5213 - 3431 - 7985 - 6145 - 4274 and activation...
Please give authorization code for adobe premiere pro 2.0 my serial number:1132 - 1285 - 5953 - 8545 - 6450 - 4790 my activation number:2870 - 2977 - 7615 - 7674 - 2817 - 4056 - 7675 and activation type:Normal 93: -2146869244 please give me only authorization code this version
Dec 12, 2011 | Adobe Computers & Internet
1992 Jaguar XJ6..vcm error codes
code 24 is the ignition amplifier circuit
Sep 08, 2009 | 1992 Jaguar XJ6
87 nissan quit code 24 and 31 shows - would it be the computer that needs to be replaced?
1987 nissan showed code 24 and 31
also made dashboard lights go haywire
PROBLEM solved by self -- DISTRIBUTOR
May 19, 2009 | 1987 Nissan King Cab
What is check engine codes 24 and 33?
Code 24 is a defective speed sensor, usually located on the side of the tranny.
Code 33 is a defective map sensor, under hood located in one of many places. It's a black plastic square in shape box, has a wire connection and a vaccum hose connected to it.
Apr 08, 2009 | 1993 Oldsmobile Cutlass Supreme
Need new codes for eurovox telewest
hey try this code
5A 01
AA B7 D1 D9 CE 8E 83 AF
A1 38 06 29 24 29 8D 2B
it works on mine
goodluck
Jan 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Kenmore 43142 Front Load Washer Logo
1,000 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
