Question about Hammering
Hi,i,m prtty sure the oiler for jonsered chainsaw has conked out
Hi,i,m prtty sure the oiler for the chain has conked out,i,ve cleaned the chain bar holes out etc but even with all the bar gear off and the motor reving high there,s still no oil creaping out,i,m not sure how to dismantle the clutch assembly ie,hold it to undo the big centre odd looking nut thing to gain access to the little worm pump underneath, any other useful info would be greatly appreciated,many thanks.simon ,,New Zealand
  • 110 Answers
Remove the chain and bar look twords the oiler and clean out that oiler port it works on gravitation thats all
Posted on Apr 24, 2010
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
Oiler on mac3516 not suppling oil to bar
Take the bar and chain off, clean any sawdust and grime from where the bar meets the body of the chainsaw. Make sure the oil tank is full but don't reassemble yet. Start the chainsaw without the bar and watch to see if any oil is coming out of the little hole or slot above the bar bolts. Check that it isn't clogged with muck. If this bleeds oil then check the bar which has an oil hole that matches up with the oiler, this could be clogged. Blow out with compressed air, also run a piece of hacksaw blade around the groove where the chain sits in the bar to clear debris and blow out. Good luck.
Dec 07, 2014 | Garden
Stihl chainsaw (Farm Boss) - chain oiler has stopped working, how do I check the fault ?
Hi John...
You will need to remove the bar and chain...behind the bar is the auto oiler it works on the shaft of the chainsaw, you will have to remove it and clean all the outlets for the oil to the chain.
Please take time to rate me
Bud
Mar 10, 2013 | Garden
The chain oiler no lnger oils the chain.
remove the chain, and the bar,, check for the little hole at the motor end of the bar, make sure its cleaned out ,, oilers very seldom go bad, they just get plugged up,
Sep 05, 2011 | Homelite Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
My saw a jonsered 670 champ keeps putting oil out the oiler tube even when the saw is shut off , until the tank is empty any ideas or fixes?
Try loosening the oil filler cap when you are finished using the saw, this should stop the siphoning of the oil. Tighten the cap again. Stephen.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 03, 2009 | Garden
Chain oiler does not seem sufficient
The chain oiler injects oil into the rear of the bar where the cover mounts over the sprocket. Take the bar off and clean out the oiler hole. There is usually some buildup of sawdust in the hole. Clean out the grove that the chain guide runs in all the way around the bar. You can see the injector nozzle under where that bar was when you removed it. Sometimes there is an ajusting screw there to increase oil flow.
Sep 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw chain oiler not working
There is probably a filter on the bottom of a hose within the oil tank. Go through the tank fill cap with a blunted rod. Move it slowly you should find the hose. Draw it gently toward the opening. You can probably find a new filter at a Husqvarna (parent company) dealer if you don't have a Jonsered dealer handy. Oil pump replacement is complicated. Any good chainsaw mechanic can replace it regardless of what saw they sell. Arboristsite dot com is a buch of chainsaw nuts (Eye r 1). They will give you better guidance. Please do a searh in the chainsaw forum before asking "how do I fix my saw", the answer has almost certainly been asked. Spike60 is a Jonsered dealer and is always helpful. HTH Lou
Sep 01, 2009 | Garden
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Hammering Logo
213 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
