Question about Kenmore 800 7982 Dryer
How do i open the console on my kenmore 800 series washer?
  • Philip May 11, 2010
    Do you have the complete model number, it should be on the rim of the top when you open the lid
    Scholar:
  • 126 Answers
THERE ARE TWO SCREWS ON EACH END ON THE BACK OF THE CONSOLE.REMOVE THESE SCREWS. THEN PULL FOREWARD ON THE CONSOLE AND FLIP UP.
Posted on Apr 24, 2010
My kenmore 800 series washer started draining but stopped 3/4 of the way and now won't do anything at all
Put the machine into the spin cycle and start as normal. Then with the lid open take a item like a pencil and depress into the lid switch where the lid pushes down on a switch. If machine starts spinning remove and replace lid switch. Let me know.
Feb 01, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
I have the series 800 Kenmore washer and when I set my dial for any of the cycles it will not turn on. I find myself trying each different wash cycle ,opening and closing the lid, etc. and the machine will...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 05, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore 800 series has a problem during the spin cycle. more often than not the machine bangs all over the place. i redistribute the wet clothing multiple times so it spins in balance. but all the time....
unplug the machine,remove the two phillips screws that hold down the top console,flip up the console,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back towards the wall and the clip will release,in between the clips you'll see the lid switch,a white plastic harness connector,unplug that then open the lid,grab the frame pull back and up and remove the frame of the washer,look at the bottom rear of the frame and the tub,you should see a spring hanging there,the hole that it was connected to rotted out,you need to drill a new hole and connect the spring to it,that spring keeps the machine from bouncing all around like it is
Nov 27, 2010 | Kenmore 22422 Top Load Washer
Wife likes to check the wash cycle on the Kenmore
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
From a liability standpoint, I cannot recommend bypassing the lid switch except during troubleshooting.
Mechanically it's simple to jump the two outer pins but again, I'd recommend against it from a liability and warranty standpoint.
Jan 20, 2010 | Kenmore 24032\24036 Top Load Washer
How do I replace my drive coupling on my 70 series kenmore washer
Your control console may open differently. Your screws may be on the rear corners of the console. Your screws may be under the end caps of the console.
Sep 17, 2009 | Washing Machines
How do you open the console on a Kenmore 80 Series Washing Machin
To replace a motor coupling on a Kenmore top loader, follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Included are all the step-by step instructions you need (including how to open the console). If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
My 800 series Washer get frozen Y want to take out the back side
JUST LIFT THE COVER UP AND USED ONE HEATER TU WARM IT UP HOWEVER THE HOT WATER DOSE NON STOP INTAKEN WATER MAY YOU HAVE SOME THING TO TELL ME ABOUT THIS ISSUE.
Fabio
Dec 16, 2008 | Kenmore 22422 Top Load Washer
How do I open the top of a Kenmore washer 80 series. Model 11092284100?
HI thanks for your question. 2 screws on each side of console. remove. lift up console. 2 brass clips , remove. disconnect lid switch connector. pull cabinet off. thanks the appliance doc. please rate my answer thanks.
Oct 09, 2008 | Kenmore Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 800 7982 Dryer Logo
1,257 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
