Question about Cyber Acoustics AC401 Consumer Headset
Cyber acoustics headset not working
Ok well i got a mic about a month or two ago and i was playing warcraft 1 day talking 2 my friends...and my mic was intangled so i unplugged it and now it wont work any help
  • 1 more comment
  • ciran May 29, 2008
    I have the same problem except I was playing CS:S, when I go in to test the hardware with my mic it shows that it's working it just has no feedback or sound for that matter, I cant hear anything, it's not muted, my sounds not muted. and when I unplug them the sound still works.
  • Anonymous Jan 15, 2009
    sorta the same here...worked fine one day, next nothing. the speakers part work. just the pic acts like its not even there. email solution or possible driver info to, [email protected]
SOURCE:
  • 53 Answers
SOURCE: Cyber Acoustics AC-840 USB Headset
heyo...for you online meetings...I am assuming you are using Skype. Check the volume settings in the TOOLS and OPTIONS, audio settings, audio in&out, using the drop down menu for microphone and speakers. Save.
If that isn't a problem, it could be a setting in Windows (also assuming you are using XP). Go into your Control Panel, SOUNDS&AUDIO, Audio tab, check your volume there.
Wayne
Posted on Dec 30, 2007
SOURCE: cyber acoustic headsets
make sure that your mic is ot muted cause thats what happened to me also check it when ur done in your audio manager
Posted on Aug 28, 2008
ziraffa
  • 827 Answers
SOURCE: My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Posted on Jan 12, 2009
romsky79
  • 822 Answers
SOURCE: I plugged my headset into my desk top usb slot and I'm not getting any sound from my headset.
use usb sound card adapter.
Posted on May 30, 2009
  • 5 Answers
SOURCE: HS 600 cyber acoustics mic isnt working...
The issue lies in the glass fiber wire, the wire is coated with a conductive metal only a fe mircons thick.
Simply put the headset is a poor production model, the use of glass fiber wire more often than not results in a short in the wiring. Thus the sound will come out of one side, not at all, etc.
Posted on Jun 15, 2009
I have just set up skype on my laptop and tried using the echo /sound test. Though my mic seems to be working I do no hear anything. I have checked the sound settings and skype does play sounds through my...
If you are running Windows 7 you can have audio set up to listen to the mic. I would not recommend this though as there is a slight delay from you talking to it coming out of the headphone. This can cause you to stumble on your words. But solely for testing purposes do this if you use Windows 7:
1. RIght click on the speaker icon in the lower right corner of your display and select recording devices.
2. Make sure the microphone you use is highlighted blue then click properties button in lower right corner of the window.
3. Click on the listen tab, then check the box that says listen to this device.wdaexodus.png
Mar 05, 2011 | Cyber Acoustics AC-201 Consumer Headset
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email [email protected]
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
I can hear my friend but she can't hear me
Jun 13, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Feb 21, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Hi Bob,
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Cyber acoustic headsets
May 26, 2008 | Cyber Acoustics AC-201 Consumer Headset
AC-740 : No Manual
does it have 2 plugs one for mic and headset or sterio plug for mono head set mono mic u would need input on phone that can accept that kinda sterio input ok for both
Jan 28, 2008 | Cyber Acoustics AC-740 Headset
Cyber Acoustics AC401 Consumer Headset Logo
158 people viewed this question
Top Cyber Acoustics Radio Communications Experts
Clementina Emerson
Clementina Emerson
Level 1 Expert
Jeffrey Groves
Jeffrey Groves
Tom Chichester
Are you a Cyber Acoustics Radio Communication Expert? Answer questions, earn points and help others
