My Sceptre monitor X20WG-NAGALL power light come on but no display
  • 6,993 Answers
the fault is from the display/picture board. The board needs replacement for your monitor to display again.
Good luck.
Posted on May 01, 2010
20inch monitor only has video for fraction of a second. then goes out. does this every minute or so. i used vga instead of dvi, same. i used mobo instead of video card, same. picture comes to second screen...
It may have power supply problem due to bad DC filter caps, bad backlights inverter circuits, and worst case will be the lamp assemblies.
You need to open it up and check the caps in the power supply section first.
Example: http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 12, 2011 | Sceptre NAGA II X20WG 20 inch LCD Monitor
Hi My monitor that i have used to let us shut off the monitor manually, it no longer does it reads key lock whenever we try to turn it off and if we try to adjust any settings it will read key lock in the...
I'm not aware of any ability to lock the keys on any monitor I've seen. I've not used a lot of Scepter monitors but it seems like a rather pointless option to have. So unfortunately the monitor seems to be malfunctioning and will have to be repaired or replaced.
The only thing i can suggest trying is unplugging the monitors power cable for a few seconds in hopes it will reset the monitors control buttons.
May 29, 2011 | Sceptre NAGA II X20WG 20 inch LCD Monitor
Display appears for 1 second only then goes black ... model x20wg-naga
Did you open it up and inspect to see if you can see any caps with bulging tops, check the 5v and 12~16vdc voltages?
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SCEPTRE and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Oct 31, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
My Sceptre x20wg has gone blank. The blue light is on and "clicks" every couple of seconds. There is no display
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre and all monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 16, 2010 | Sceptre X20WC (Black) LCD Monitor
Sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Oct 29, 2009 | Computers & Internet
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
32" Sceptre LCD No POwer
0939a31.jpg This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me pbj0327@yahoo.com.
Thanks! and good luck m007!
Nov 28, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
