Question about Yamaha HTR-6160 Receiver
Reciever keeps on shutting off and it say check speaker wirer
My yamaha reciever keeps on shutting off when i turn up the volume when I switch it back on it says "check speaker wirer" how can I fix this?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Just a wild guess but it could be fixed by replacing all your speaker wire or checking it for breaks. Look for tiny teeth marks if you have a small dog or a mangled mess if you have a big dog. Is the wire running under a cabinet or furniture which touches the ground, perhaps it's been fractured by the pressure. Has the wire been pulled out of the speaker itself or possibly the rear of the amplifier. Some speakers and amps use the old insert bare wire and twist the connector type connection. Others use speaker cable with plugs on one or each end. It's possible that the wire has been fractured or pulled away from the connections inside the plug. This would be readily apparent and certainly not visible. The only way to properly check would be with a multimeter. If you don't have one maybe a friend has got one and can help you check the wiring Another way to check is to physically put your ear to each speaker in turn (with the volume at a low level) If there is a broken wire the speaker concerned you wouldn't hear anything being emitted. When you are checking make sure that all speakers would normally be working if everything was OK.
If there are bare wires anywhere in the system make sure they aren't touching. Just a tiny filiment of wire in the wrong place will cause a warning to come one.
The last thing that it could possibly be is a damaged speaker caused by overdriving it which would overheat the voice coil and cause a short circuit.
You would pick this up when you listen to them one at a time. Nothing would be heard from that speaker. This problem would be seen by the amplifier to be a wiring problem.
So visually check all wiring for breaks or crossed bare wires. Bad kinks, wire under strain, wire with marks of being squashed under furniture etc.
Do the listen to each speaker test.
Find a friend with a multimeter to help you.
Finally disconnect all your wires, put a tag on each one to remind you which speaker it connects to and take the lot to a repair shop. It would take 10 minutes to check all the cables for continuity or failures. Get the tech to replace the broken cable with one the same length and then go home and reconnect them.
Just a word of warning. Don't continue to use them in this condition and make sure anyone else in the house knows the same as it could cause permanent damage to the amplifier. Better a simple check now than spend a fortune next month or week. Another tip, if your cables have plugs on them, always pull the cables out of the socket by grasping the plugs, not the cable.
Happy listening.
Posted on Apr 24, 2010
Testimonial: "Very knowledgeable and detail thank you for your quick response."
I have a Yamaha HTR 6180 reciever and 2 AR 328ps speakers one of the speakers when turned up with shut the reciever down I did a prosses of elemination and took each speaker out of the tower individually...
A capacitor is more like to fail than a coil, so I would also suspect a cap first. Capacitors conduct high frequency more than low frequency, so this may explain the extra load and shutdown on high frequencies.
Jan 21, 2015 | Yamaha Audio Players & Recorders
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
My yamaha rxv595a keeps on shutting itself off when im watching movies as soon that it gets loud it shuts off but its not even that loud how do i fix this problem i tried the ohms switch in the back and it...
That is a safety switch in most receivers. When something gets too loud it cannot give the load off to the speakers and shuts off to protect itself. This can mean that the receivers getting old, or that you might need to split the job. You might need an stereo amplifier to split the job. Check the cables and speakers. Recievers can only give so much to so many speakers at so much sound. That is what the whatts are for. The more whatts the better, the lesser whatts, the lesser speakers its going to be able to handle at high volumes.
Feb 28, 2011 | Yamaha RX-V595A Receiver
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
It turns off with an error to Check Speaker wires. It's done this in the past, usual if I push the volume too it's threshold. It would always bounce back. Now it shuts down at just about it's mid-peak...
Did the fact that it was responding negatively to the loud volume not suggest it might be a bad idea to keep doing it?
The threshold on the volume knob is NOT where normal undistorted listening levels are found. Given a normal level of input you could be pushing your amp so hard that it clips or distorts and kills your speakers.
Do what it asks: check the speaker wires for shorts. Or disconnect the speakers and pray it comes back to life, then isolate the shorted (dead) speaker.
Feb 23, 2010 | Yamaha RX-V657 Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
MY YAMAHA RECIEVER KEEPS SHUTTING OFF
The unit is going into protection mode. The message is a generic one and usually means that the output section is drawing too much current and has been shut down. Defective speakers can cause this, but in this case, I suspect that there is a problem in the front end that is allowing DC current to pass to the output circuits. This will cause a problem that will shutdown the system. Yamaha designs are not the most straightforward nad I would not suggest you attempt this repair without prior repair experience. Take this to a service center and request a detailed repair estimate and report the results here. Armed with that info, we canguide you further.
Dan
Jul 19, 2009 | Yamaha RX-V663 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Amp switches off at about -10db volume level
I suppose that on all speakers connections + (positive) is on +, and - (negative) is on - ?
Oct 08, 2007 | Yamaha HTR-5830 Receiver
Yamaha HTR-6160 Receiver Logo
174 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
