Question about HP Photosmart R817 Digital Camera
I have broken my HP Photosmart R817
It fell down and some pices fell out from lense,,, i think its nothing serious, but i dont know which part goes where... please help!
  • Anonymous Dec 25, 2008
    What happens of one of the strings is missing?
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Posted on Aug 10, 2008
SOURCE:
My lenses wont retract and my camera has a error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2010 | HP Photosmart R817 Digital Camera
Images are green on camera and on screen session referenca # 922077
i think, .you should change the photo shooting mode.otherwise you reset your whole camera settings.if the problems will continue then you will change your lcd screen.
Jan 13, 2009 | HP Photosmart R817 Digital Camera
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
Zoom is broken
just call bob the builder; because 'yes they can"
Oct 28, 2008 | HP Photosmart R817 Digital Camera
Lens won't retract
Mine has done this twice, both times requiring it to be sent off for repair, both covered under warranty though luckily. Both came back saying they replaced the shutter assembly. Camera is fixing to go back out for a third time (not shutter related). I've lost all confidence in canon with this one.
Oct 25, 2008 | Canon PowerShot SD870 IS Digital Camera
HP Photosmart R817
Something is wrong with the battery or the charging system. I just charged it over night and it works now. The battery still dosn't last very long .
Oct 07, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 5.1 Megapixel
Lens does not come ut when we turn camera on?
Jun 30, 2008 | HP Photosmart R817 Digital Camera
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Screen not working
It could be that the connection to the screen has loosened up for some reason. If the warranty is void you can try to open it up (if you're up to it), taking the bottoms screws out, and then only the one's close to the screen side on the sides (hehe I hope you understand what I'm trying to tell you ;) )
The screen should be the first thing you see, if you loosen the 4 screws that hold that you can see the connection, just try to fasten it a little bit better, and then screw everything back to it's place.
Let me know if that didn't do the job :)
*I can not be held responisble if you decide to take something apart, It's your hands*
Feb 15, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 Digital Camera Logo
233 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
