Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher bosh SCH4c02UC does not start- power does not turn on.
  • Bosch Master
  • 2,605 Answers
Hi, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on Apr 24, 2010
My Bosch does not wash well
Clean Your Dishwasher with Tang (yep - the citrus drink)
  1. Empty the dishwasher.
  2. Run the water in the kitchen faucet until it is hot. (He suggests you do that before running your dishwasher every time.)
  3. Turn the tap off and start the empty dishwasher.
  4. After two or three minutes, stop the dishwasher and add a container of Tang.
  5. Let it run the whole cycle.
Jan 01, 2014 | 1993 Mazda RX-7 Brake Pad Set Bosch
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few seconds
Read more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhs
please feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok
Best regards Mike
Dec 04, 2012 | Bosch SHU9915UC Dishwasher
I think the rinse cycle is not working on my Bosh dishwasher. It is leaving a soap residue on the dishes.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 14, 2011 | Bosch SHU9915UC Dishwasher
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosh dishwasher not starting
Since the power is fine, now to get to the issue. You will need to pull the front panel and see if there is power to the on/off switch. There should be the same as what is at the junction box of the incoming power. If there isn't the proper voltage there, then you have a broken wire. If the voltage is there, then check the voltage going over to the control with the on/off switch in the on position. If power there and not lighting up or starting. Then the control is bad.
Jan 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher does take electricity
MAKE SURE THE DOOR LATCHING MECHANISM IS OKAY IT HAS A SAFETY POWER SWITCH CONNECTED TO IT
ALSO USE VOLTMETER TO MAKE SURE THE AC SOKET ITS CONNECTED TO IS GETTING POWER
Jan 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Sep 09, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
